Oil & Fuel Can you hear your fuel pump?
   / Can you hear your fuel pump? #1
Evasive1
Osage County in Oklahoma green country
Century 3045 (48 hp), R-4's, C50 HL loader, C-86 BackHoe, Cub Cadet Z-force 44 and 1042
Usually when I start the Century 3045 (45 hp) during preheating I could hear the fuel pump making its usual noise. Early this winter one time when I went to start it during the preheat cycle the fuel pump was silent. It started right up though. Ever since then the fuel pump makes no noise but the tractor still fires right up and runs great still. So it got me wondering.
Can you hear your fuel pump on your Century/Branson during preheating?
   / Can you hear your fuel pump? #2
Hi, yes I can and did hear my pump. Your pump should be heard while pressure is built up, then quit and continue again when it needs fuel again. My tractor once shut down because I wasn't getting any fuel to the injector pump. My fuel pump was rattling away (normal run/ satisfy,blurb/run) noise. Plenty of fuel. Checked filter, restrictions, cuts nicks, etc. When I took the hose off it would pump fine, but when you put the slightest restriction over the end of the hose it would stop pumping, and the injector pump would go dry. I switched it out with an electric unit I keep for stock/emergencies, and it started right up.
   / Can you hear your fuel pump? #3
Hi fjb2c, could you please read my post about possible air in system. I dont think it is a pump issue as its cycling/running and changes pitch while monkeying with fuel shutoff or opening up a bleed screw on the top of the filter housing. But I think its air locked betwen the filter to the injector pump. It appears there is a banjo type fitting where the fuel line enters the injector pump with a possible bleeder bolt as part of the fitting at the injector pump. Can I bleed air from that fitting?
Thanks
Mike
   / Can you hear your fuel pump? #4
I did unfortunately have to crack the PAINTED fittings in order to check for air. There was no air. I took the fuel hose off to check fuel pump pressure and found out that there was none either at the discharge fitting of the fuel pump itself or the injector pump inlet fitting (bleeder).
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2025 AGT 750 (A50123)
(INOP)NISSAN 40 WAREHOUSE FORKLIFT (A51247)
(INOP)NISSAN 40...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
