Can you give me an approximate value for this tractor
   / Can you give me an approximate value for this tractor #1
clydesdale
It is a 545d and starts right up. I am not sure what this tractor is worth. Could you give me a range? It has 1800 hours or so on it. I am selling it for the condo that I live in. Thanks.
   / Can you give me an approximate value for this tractor #3
I'd say on the lower end of that scale. They sell tractors like that (but with a backhoe..eg: 555) around here for $13,000 or so. I'm gonna say its worth around $8k or $9k sir.
By the way...what year is it...4wd or 2wd...pto ?
   / Can you give me an approximate value for this tractor #4
yea the lower end i seen them sell at auction as low as 4500 and as high as 10,500 but 7500 to 12 is about normal price
   / Can you give me an approximate value for this tractor #5
4k would be too low and a bargain for anyone. 7K would be a pretty fair price, above that the advantage goes to the seller. Below 7K the advantage goes to the buyer.
   / Can you give me an approximate value for this tractor #6
That tractor probably started life with a big boxblade on the rear and hydraulic actuated scarifiers. The condition of the 3PH, remote hydraulics, and if the tractor has a PTO (probably not) would have a lot to do with value; I'd think as much as $2k to $3k difference depending on what is there and how it operates. From your pictures, all we can tell is that it has a big FEL and probably runs well from your description.
Here's a picture of the rear of a 2002 545D from Machinery Trader. It appears to have TnT cylinders and also a PTO and drawbar. If the 545D above has all this, then it's a top-notch tractor.
Here is a pic of the rear of the tractor.
   / Can you give me an approximate value for this tractor #8
Still need the year sir...and 2 or 4 wd ?
Sorry, 4wd and I am working on the year. It is from the 90's. I have several serial numbers can you tell me where the one with the year would be located? Thanks.
The tractor has 3 serials.
05195
9622619
L5nn4012e
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2016 Isuzu NPR Box Truck (A51692)
2016 Isuzu NPR Box...
2014 Nissan Versa Note Hatchback (A51694)
2014 Nissan Versa...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
