hangnail
Just want the title says, can you get a a independent deck lift so you can operate the 3point lift indepeantly of the mower deck?
hangnail said:... can you get a a independent deck lift so you can operate the 3point lift indepeantly...?
lp333 said:That hydraulic control raises and lowers both the 3pt hitch and mower deck together. The design dates back several decades to early models like the B7100. However, the newer BX design is more refined and works better. What application did you have in mind that might require independent controls?
Harry c said:Hangnail,
Sounds like you need to look at the Kubota grass catcher. It runs off the PTO and apparently is not affected by the 3 point hitch position.
the kubota system has bags though right, i would rather not have bags, im not even that keen on the trac vac becasue of the barrels, but would deal with it for its compactness
