Can you drive a tractor on three wheels?
   / Can you drive a tractor on three wheels? #11
If you look down at the bottom of the page below "reply to thread" you will see "similar threads", then links to (apparently) similar discussions; in this case 5 titles which had "wheels" in the heading.
Cool! Thank you; I never ever noticed that.
   / Can you drive a tractor on three wheels? #13
If it doesn't have one put a tube in it and forget about it. I had one front tire that would always slowly leak down. If it got low enough it would come off the rim. There's no bead like a car tire has. Simply the tire getting traction and the tire slipping on the wheel is more than enough to get it to come off. The first time it happened to me I had the local tire guy air it back up and order the correct tube for it. The second time (and last) I put the tube in.
   / Can you drive a tractor on three wheels? #14
We were towing a swather 200 miles in September when 10 miles into the trip a crack in the left spindle housing failed. We removed the broken spindle and wheel, found the axle stop held the axle end off the road, so continued the remaining 190 miles on 1 rear tire. It wore on the edge but not to the cord.
   / Can you drive a tractor on three wheels? #15
RFC
Nice blower- i have the 74
Have you replaced the cutting edge?
did you make your own?
Wow. Forgive me for not searching first, but really?? Driving on three wheels? Should have known someone's gone before.
As it turns out, I failed to save the tire (probably in the first 50', without the bucket down), and cut the bead. Lesson learned. When I get the wheel back on, I'm going to try blocking one side and seeing how it feels; got plenty of weight on the back (Pronovost RP-INV-80...about 1000 lbs), to help take the load off the front.
RFC
fishhead: Is the "cutting edge" the same as the "scraper blade" on the back? If not...that is if it's at the bottom of the main auger, then no, I haven't replaced it but think I may need to. No matter how I adjust the unit, it leaves a 1/4-1/2 "film" of snow on the ground. Are they easy to replace?
   / Can you drive a tractor on three wheels? #17
Then you壇 flame him for reviving a zombie thread. Why don稚 you stop and think what would happen if nobody ever started a thread that痴 already been discussed. Might as well close the whole forum because until electric tractors come out there isn稚 much left to talk about.
Crickets... :)
   / Can you drive a tractor on three wheels? #18
And I didn't take it as a flame. As a matter of fact I was going to ask him what he meant by "This 15 YO discussion turned up as a suggestion". Is a "Suggestion" just a search result?
I'm always interested in learning how to search better.
Down at the bottom of the page it gives a list of "Similar Threads". 👇
   / Can you drive a tractor on three wheels? #19
i mean the one under the auger- its time for me to replace it- i'll try to take some picsand share any learning
mine occasionally leaves a bit of a film but it seems to depend on the type of snow/speed of the tractor and tilt of the blower. I don't have the rear blade but have been thinking about the rear wheels.
   / Can you drive a tractor on three wheels? #20
I know this doesn't count, but, I have to say that the beauty of my tricycle tractor was that if one front tire went flat, I could limp home on the one that was still inflated. I also miss being able to lock one rear wheel and turn in place.
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
Jack Daniels Wall Art (A55853)
Jack Daniels Wall...
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
