Can you deduct tongue weight if you are over axle capacity?
   / Can you deduct tongue weight if you are over axle capacity? #11
My brother in law was a state trooper in truck weight enforcement if he saw a trailer with the wheels bowed from overload, after the fines you will park it and pay to get it back. I see people all the time with utility trailers with a pile of wet mulch on the side of the road with an axle snapped off. Your situation with no ebrakes and have to stop suddenly could be catastrophic.
   / Can you deduct tongue weight if you are over axle capacity? #12
rent a trailer. or uShip | The Online Shipping Marketplace and have someone else deal with it.
but your comment of already having an axle on it and 4,000lbs sounds like it is already designed to be placed on road. possibly even a license plate spot some place on the rear end. 4,000lbs seems rather beefy chipper unit! not talking a little 3pt hitch unit, that lifts up and down with 3pt hitch of tractor. but a unit that requires a wheels. and most likely a tongue on it to be pulled like a trailer. vs connection to 3pt hitch linkages.
   / Can you deduct tongue weight if you are over axle capacity? #13
IF you were to be stopped, the only thing that matters is what each axle weights (and what the tires are rated for) and that none of them are over.
So if you put your 4000# load forward, and lets assume the trailer weighs 800#.....There will be 4800# behind the truck. IF you loaded it with 1300# tongue weight or more....that puts less than 3500# on the trailer. If the truck axle dont go over its rating or its tire rating....And you arent exceeding the rating of the hitch's tongue weight.....then yes you would technically be legal.
However I havent seen a single axle utility trailer that I would trust with 1300# on the tongue.
So short answer is YES tongue weight does come off the trailer rating. But with an uneven load being nose heavy.....you can still do some damage and may not be a safe load.
   / Can you deduct tongue weight if you are over axle capacity? #14
In Ohio your mortar mixer, log splitter, air compressor and the like do not require a plate. Sixteen hour is not a short trip and I doubt very much if this is taken into
the design of a non commercial chipper. Wild ride if you get a flat on the trailer.
   / Can you deduct tongue weight if you are over axle capacity? #15
FYI-
With Semi's larger trucking companies will have their own scales.
When a load is close on the weight they will scale it, then adjust the trailer tandem with slider rails to be legal.
There also is a slider rail on the 5th wheel that can be adjusted for weight distribution.
Overweight fines are very expensive!! And it is normal to make the truck/trailer unload the excessive weight before moving. Also expensive.
Do you have something like U-Haul in Canada that rents trailers. They normally have surge brakes so no controller needed.
   / Can you deduct tongue weight if you are over axle capacity? #16
Awwwww,,,,,,, 13 posts into this thread before logic shows up.
I have nothing to add to this post. Spot on.
   / Can you deduct tongue weight if you are over axle capacity? #17
I've "snuck by" on many overloaded trips, but short trips. The only trouble I've ever had was on a long, hwy speeds trip, usually I believe from overheating the tires that are at or near their capacity. Road side trouble really sucks 8 hours from home.
   / Can you deduct tongue weight if you are over axle capacity? #18
A trailer rated for 3500lbs has already considered part of that weight will be on the tongue. You would be wise to check the ratings of the tires and make sure your bearings are greased. I would be tempted to run at a higher cold psi on the tires to help with the over heating issue. I have heard, but not confirmed that many trailer tires have a note that says you can tow faster by inflating 10psi over. Make sure to have a spare (maybe two if you can borrow a second one) and basic tools to change a tire. Make sure the trailer lights are working properly.
   / Can you deduct tongue weight if you are over axle capacity? #19
Overloading only applies during commerce (commercial motor vehicles). Civil liability applies always.
There are no violations for a recreational driver overloading their GAWR or GVWR. Those are recommended weights by the manufacturer. It's no different than putting too much Ikea furniture in the back of your minivan... You can't be ticketed for that as long as the load is properly secured.
However, if you get into a serious accident that requires a comprehensive police investigation, it will come into play. If you are responsible for the accident, and it is determined that you overloaded the vehicle, it will likely contribute to your negligence.
If you were NOT at fault in that serious accident, an attorney will still make an effort to claim you were partly responsible by making your vehicle unsafe to be on the road, and you'll likely be sued.
If you're still intent on making the trip, it would probably be safer to load the weight in the back of your truck, as far forward as possible.
And again, going over your GVWR or GAWR will not be enforced in non-commercial applications.
   / Can you deduct tongue weight if you are over axle capacity? #20
I have an ugly double axle dump trailer albeit with a valid safety, and several offers to borrow tandem trailers. The problem is I don't have a yellow safety sticker on my truck and doing so would require the E-Brake to work. Another expensive GM abortion along with those retarded disk brakes. That and who knows what front end work to safety. For one trip. But, it's looking like that might be my best option.
As far as the axles. Wouldn't you think a 3500lb axle would actually be able to carry much more if you figure in the Dynamic forces it can encounter in normal use?
I was more wondering IF it would work, not so much the legality. If I get stopped, I may well have a host of issues anyway. I'm guessing, betting, that a single axle trailer wouldn't get a second look, unless of course, the axles are nicely bowed!
Hot tip for you! Last week there was a safety/spot check on ALL pickups and cars including vans towing trailers on the 400 at Barrie. Overloads were forced to go get increased licenses and commercial plates BEFORE they could proceed with the said trailers.
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
2239 (A51244)
2239 (A51244)
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
40006 (A55788)
40006 (A55788)
