Buying Advice Can you add a loader to a M135GX?
   / Can you add a loader to a M135GX? #1
overslope
Case mx110, Case jx95
Pretty sure I found a killer deal on a M135GX DTC, but it doesn't have a loader. Could be a deal killer. I ran into the same issue on a used Case awhile back and the dealership acted like I was asking them to install anti-gravity. Said it could only be done at the factory unless you wanted a gummed together mess. Completely talked me out of the tractor.
The wife just told me to call first thing in the morning and put down a deposit. Only sticking point is the dang loader.
So, can you add a loader to this model if wasn't built for it? If so, are there any downsides vs factory equipped?
Thanks for any help, y'all.
   / Can you add a loader to a M135GX? #3
Had a loader on my M135GX. Its a dealer installed option, not available factory installed. Will probably find a better deal on a loader other than Kubota - at least that's what our dealer did to install a loader on our NH TS115A. Instead of a New Holland loader he put on a different brand. Its the same dealer from whom we buy our Kubotas.
Thanks for the info, and dealer confirmed they could install. Only problem is that they already sold the tractor.
They've got an M108 I'm thinking about. Same deal, no loader but they can install.
So, is there another brand loader you'd recommend? Dealer said around $8k installed, but I'd love to find a less expensive option. At that price it makes a really good deal just an ok deal.
Thanks again.
Edit to add: how did you like the M135? I was pretty excited about it. The M108 is considerably cheaper, but kinda feels like settling after considering the M135.
   / Can you add a loader to a M135GX? #5
Of those 2, which one do you like more & why?
   / Can you add a loader to a M135GX? #6
After market loaders are made to fit as many different makes and models of tractors that they can. A kubota loader is designed and made for a specific tractor grouping. That means the mounting is specific and designed by the people that designed the tractor! No chassis issues! The cylinders and valves are built to maximize the tractors hydraulic systems pressure and gallons of oil potential. So you may save some but it will never be as good as the Kubota!
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
SHOULE LN-16 LOT NUMBER 132 (A53084)
SHOULE LN-16 LOT...
John Deere 8400R MFWD Tractor (A53342)
John Deere 8400R...
