Can you add a loader to a L2950 that has a cab?
   / Can you add a loader to a L2950 that has a cab? #1
clayhardock
Cochrane Alberta
JD 2720 & 2305 & F932
I'm looking at an L2950 that comes with cab, belly mower and 3pt hitch snowblower, but, no FEL. Was thinking that if I needed one I could add one but then realized that maybe it didn't have a loader as maybe the cab interferes with the FEL mounts.
Anyone have a 2950 with cab and FEL?
   / Can you add a loader to a L2950 that has a cab? #2
With a factory cab your loader will have a remote joystick linked with control cables to the hydraulic control, the stick will stay in the cab if you remove the loader.
   / Can you add a loader to a L2950 that has a cab? #3
There wasn't a factory cab for the L2950. The most common cab on them is the Sims or Curtis with narrow windshield. There's no interference with a loader. There were a few wider cabs like Laurin's where a remote valve setup is needed but otherwise it is compatible with a loader.
Thanks for the replies. So what I'm hearing is that it won't interfere with the loader mounts but may need a different/remote joystick control.
Can you still get loaders for a L2950 new or just what I can find used?
Here is a pic of the tractor and cab.
What about adding a BH? Will the cab interfere with that?
   / Can you add a loader to a L2950 that has a cab? #6
Compare your pic with the ones above... I don't see the loader mounts working with the lower cab portions... Looks to be a custom built cab... I'd say no way!.
As for the BH, shouldn't be a problem... They either use a sub frame or the 3pt hitch...
   / Can you add a loader to a L2950 that has a cab? #7
......Here is a pic of the tractor and cab.........
Pretty unusual and unique cab design. Firefighter is right - looks like a lot of modification. If you are really after a loader and backhoe, you'd be better off finding a tractor that already has them. They are expensive new, can be very hard to find used, and fit-up is going to be a project in this case.
   / Can you add a loader to a L2950 that has a cab? #8
If your looking for Both a Loader & Backhoe, you need to contact manufactures and see if they have the needed sub frames along with those attachments.
If you are only looking for the loader on that tractor, call Everything attachments: Everything Attachments NTC32 Tractor Front End Loader
They have a loader for NewHolland & Kubota tractors that just may fill your need... KennyV
Thanks for the info. I had the same thought about the cab interfering with a loader. Thats probably why it doesn't have one.
I'm really thinking about this one. Not sure about it. Don't need a BH or a bucket at the moment. Need a mower for my grass cutting company next year and this would fit the bill. A bit low on HP, was hoping to run a 7ft mower but could do with the 6ft. Just didn't want to limit my options down the road.
It does come with a nifty 2stage forklift attachment for the 3pt as well. Mostly I had wanted a FEL to mount forks on and move stuff. This would be way better.
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Ford Super Duty Pickup Truck Bed (A49461)
Ford Super Duty...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2008 SHOP BUILT  STEEL TANKER TRAILER (A50854)
2008 SHOP BUILT...
