Can the T474 work with 2-row planter?
   / Can the T474 work with 2-row planter? #1
saxon11
Minnesota
TYM T474
   / Can the T474 work with 2-row planter? #2
No, it is not too narrow. It might even be overkill for that little planter. I've got some experience with food plot corn planters. I will tell you, with the light weight corn planters, your soil has to be tilled like a garden to work well. I have used old style two row planters before, and a lot of the seed ended up on top of the soil. I ended up buying a JD 7000 4 row planter, and it works very well. I was pulling it with a 25hp massey ferguson tractor. I recently sold my massey, now have a TYM T394. This tractor will pull my planter with no problems at all.
@Scut 4 Big Bucks For cultivating, the distance between rear wheels is 31", which I'm thinking would work well using a one-row cultivator as I can straddle the corn. Based on my drawing is this a good plan? Possible I could just up to even larger implements such a 3 or 4 row planter, and 2 row cultivator based on spacing and tractor's 47 HP? Am I missing any considerations here (my first time doing it).
Assumptions: I'll have the ground well tilled prior to planting and my sweet corn spacing can be set to somewhere between 28" to 36". thank you
10222 (A56858)
10222 (A56858)
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2013 Dorsey Pitts 48ft. 40 Ton T/A Flatbed Equipment Trailer (A60460)
2013 Dorsey Pitts...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
