Can the L4060 run a front snowblower?
   / Can the L4060 run a front snowblower? #1
JerkyChew
shopping
Sorry if this is a dumb question but I can't for the life of me find a real yes/no answer. I'm looking at a used 2019 L4060 with a mid-mount PTO. I asked the owner if the mid-mount PTO meant that it could run a front-mounted snowblower and he said yes, yet all I can find for L4060 snowblowers are rear-mounted models. Can somebody confirm whether a front-mount unit will work or not?
   / Can the L4060 run a front snowblower? #2
That's what the mid mount is for,that and maybe a broom.Call your closest dealer to confirm.
   / Can the L4060 run a front snowblower? #3
   / Can the L4060 run a front snowblower? #4
I’m not sure why it wouldn’t throw snow very far if it’s front mounted and powered off the mid pto. If Jeff’s link is in regards to a hydraulic powered one, I can see it not being great.
  • Good Post
Reactions: JWR
   / Can the L4060 run a front snowblower? #5
The L60 series front mount snowblowers will perform just fine. Plowing is likely faster under most conditions for practically any blower vs plow comparison.
The manual hitch is around $3k, and the blower about $7.5k. I considered the auto hitch with a plow, blower, and broom, but it gets expensive real quick. The auto hitch alone is $12k.
   / Can the L4060 run a front snowblower? #6
You guys must not get very much snow because no way any plow will out perform a blower with the snow I get. At least not in a driveway application.
Highway plowing yes, plow is faster.
I absolutely HATE plowing. My F550 plow truck stayed parked and I used my little B2620 with blower. The blower even keeps the base cut down better than my Boss vee plows.
   / Can the L4060 run a front snowblower? #7
I should have qualified my statement for my particular area and snowfall. If I needed to deal with significant snow amounts, I would definitely prefer a blower.
   / Can the L4060 run a front snowblower? #8
I just bought a L4060 with a L4479 74" front snowblower. I hope it has enough power for it. They also make a smaller L4469 snowblower, I think it's around 64" or so.
They also make a L4474 and a L4485 front snowblower. Those are the commercial models and probably need more HP.
The mounting kit is is a L4455A.
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A57453)
2016 Ram 4500...
2001 B&G Low Boy Semi Trailer (A57148)
2001 B&G Low Boy...
BUSH HOG DISC (A58216)
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
New/Unused Electric Golf Cart (A57453)
New/Unused...
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
