can someone tell me difference between the -MD134953-MHI and the same filter without
   / can someone tell me difference between the -MD134953-MHI and the same filter without #1
hturner12
Thomaston ga
LS Xg 3025
I can cross the basic number to a Wix for about 10 bucks at Oreillys but can not cross the one with the MHI suffix. The hyd filter is 39
   / can someone tell me difference between the -MD134953-MHI and the same filter without #2
What is the MD134953 filter for?
If you are looking for hyd. filters for your XG3032 they are:
HST 40007563 = Wix 51551 = NAPA 1551
HYD 40007638 = Wix 51715 = NAPA 1715
  • LS FIlter Chart.pdf
It the oil filter. Napa wants 67 for the hyd filter.
   / can someone tell me difference between the -MD134953-MHI and the same filter without #4
I think I made a mistake. I listed filters for the XG3032 and see you have an XG3025. Not sure if the HYD and HST filters are the same.
Double checked and HYD / HST are the same. I've included an updated filter list.
I'll see if I can find out a cross for the oil filter.
Oil filter#40056451 crosses to a WIX 57040, NAPA 7040, Fram PH6607
  • FIlter Chart Rev 2 06-07-2016.pdf
I got the numbers from the post that had the xg3025 parts manual. I think the only difference in the xg and g are the engine. difference in my tractor and yours is mine is 25 hp and yours is 32. I know the MDI is the engine type but I do not see how teir 4 emissions would affect the oil filter
   / can someone tell me difference between the -MD134953-MHI and the same filter without #6
See my post#4 for oil filter and chart for the XG3025 LS filter numbers. My tractor XR3037HC is 36.2 HP.
Mine has Shibaura engine, some older tractors had Mitsubishi engine, Most new LS tractors have the LS engine. I believe yours has a Mitsubishi engine because the HP is under 26. Wix crosses the MD134953 to a 51365
no mine has the LS engine this year they did there own tier 4 for the 25 hp last year was the other engine.
I found that cross but what is throwing me off is the MHI at the end of the part #
OIL SYSTEM
Q140S01-04 25,27
02
NO PART NO PART NAME SPEC QTY REMARK
1 40219852 VALVE ASSY, RELIEF 1
2 40224916 GASKET 1
3 40219853 OILFILTER-MD134953-MHI 1
4 40056451
   / can someone tell me difference between the -MD134953-MHI and the same filter without #9
The MD number you posted (without the MHI on the end) crosses as a Mitsubishi engine filter.
Just buy from your dealer. Or if you haven't bought the others yet, RCO has a filter package. 1-oil,1-fuel, 1 air, 1 HST filter.
RCO Tractor - Filter Kits for LS Tractors
The 8 digit numbers are the LS part numbers. Your oil filter (item 3 on your list) would be 40219853. Being a new tractor model the aftermarket may not have a cross reference yet. My tractor is a 2014 and I waited 1 1/2 years for the aftermarket to catch up. Up until now I've been using filters from my dealer.
   / can someone tell me difference between the -MD134953-MHI and the same filter without #10
The #4 part number in your post is the same oil filter number I posted (40056451) in post 4 which does cross reference. Its the number listed on the pdf of LS filters.
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
