Backhoe Can someone show me pics of BX24,25 subframe
   / Can someone show me pics of BX24,25 subframe #1
cschulz
Ortonville,MI
Kubota BX2660
Hey guys, Im interested in seeing what a subframe looks like and how it attach's to a BX24,25 to support a back hoe. I may have an option to purchase a BH from a 24. Dont know what happen to the rest of the tractor but the BH is like new.:thumbsup:
Thanks in advance, Chris
   / Can someone show me pics of BX24,25 subframe #2
If its like my 23 ther isn't one
   / Can someone show me pics of BX24,25 subframe #3
I did the best I could shooting some pics off my BX25. With the backhoe on it was tough. Like trying to tell someone how to put their coat on. Basically, the two lower pins on the hoe lock into a hook; the two upper pins are then inserted to lock the hoe in place.
Good Luck.
   / Can someone show me pics of BX24,25 subframe #4
I found a pic with the hoe off the back of the BX25. However, I do have my homemade trailer hitch in the way.
Thanks guys. Artisan the search was just what I needed. The very first schematic showed me how its put together and all.
Thanks Chris
   / Can someone show me pics of BX24,25 subframe #7
cschultz, there was a very enterprising fellow (wills670) that adapted a BX24 BT601 BHoe to his BX2200 and he has reported great reviews for it.
He custom made the subframing for it and posted a pretty good step by step on his mod.
Do a google search on "Got my brackets cut out for backhoe mod." and you should find several threads on it.
Good luck, it can be done.
Dave
   / Can someone show me pics of BX24,25 subframe #8
Are you sure you want to buy a BH from BX24 ? the value of BX24 will go down dramatically since its missing the B from the TLB it was designed to be. If you really want a BH for your tractor, you might be better off with a woods unit as its designed to be hooked on a 3 pt and has pto hydraulic pump, etc.
The BX24 BH DEPENDS on the HST oil from the tractor. You will be spending alot of money to add a subframe, pto hydraulic pump, oil tank, pto hookup, etc.
I would say its cheaper to get a woods unit.
Dave
Thanks Dave, I will take a look and maybe contact the man.:thumbsup:
The BX24 tractor is not there. Dont know if it was sold or what but the BH from the BX24 will operate from my tractor hydraulics. Just need a few lines to hook up. And of course a frame.
Chris
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2016 Komatsu WA380-8 Articulating Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel (A59076)
2016 Komatsu...
1999 Peterbilt 379 Tandem Axle Road Tractor (A55272)
1999 Peterbilt 379...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
SCALES & PEA (A58374)
