Can someone help me identify this ford Power Steering Box Column?
   / Can someone help me identify this ford Power Steering Box Column? #1
CobraTom
JD 3520, Kubota B3030
Can someone please help me identify this Ford Power Steering column/box? I purchased it at a storage auction and the only markings on the box are as follows:
Box itself:
Leys 30-00-01-479
and then engraved on the box (after rebuild I assume):
RC 180 then the date rebuilt and then BC
I really appreciate all help and assistance! Thank you!!
   / Can someone help me identify this ford Power Steering Box Column? #2
Looks to be a box from a machine with a cab... likely a Ford 4610 or similar.
   / Can someone help me identify this ford Power Steering Box Column? #3
depending on the bolt patern on the bottom it could be a late model 4000 a 4600, a 340a or 4610 also fits a 2600, 3600, 4100 cab tractor if the small bolt pattern if the large bolt pattern it can fit a late model 5000-7000 a 5600, 6600, 7600 and a 5610, 6610, 7610 with fit cab or open station depending on the length of the top shaft
if you are wonting to sell it where or you located i might be interested in it
   / Can someone help me identify this ford Power Steering Box Column? #4
I had one of those off a 7600 several times trying to get it to stop leaking under the steering wheel - never fixed it. Top shaft looks shorter - probably interchangable - next shaft down is $1200 at CNH.
Bob
Thanks for the responses. What are the bolt patterns? I can measure the unit and compare.
I fully intend on putting the unit on ebay as soon as I figure out what it is out of!
Thanks again!
This is the best I can come up with, I have a feeling this is a rebuild by
Walts Tractors, please see:
Rebuilt Steering Box (CC*)
UF00028 Rebuilt Power Steering Box
Fits: : 4000, 4600, 4100 Dunham Log Hog, 340, 540, 4610, 1970 - 1990; Must Use Adapter Part #90026
For Return Line On 1981 - 1990 Models
$450.00 core charge included in price
To Receive Core Charge Refund:
Core Must Be Returned Intact(1 Piece),Visually Inspected & Deemed Rebuildable
The last two look very similar except for the fact mine does not have the ears on the top of the shaft.
Thanks again!
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A53426)
2005 INTERNATIONAL...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Alliance Flotation Tire (A50123)
Alliance Flotation...
2015 Dodge Dart (A51694)
2015 Dodge Dart...
2012 Manitex 50110SHL 50-Ton Boom Crane Truck (A53117)
2012 Manitex...
