Can someone help me ID a PT?
   / Can someone help me ID a PT? #1
McGrewequipment
This machine has the Duetz F2L-1011F Engine. It has 26x12.00-12 tires. It came from a military base and the hour meter shows 98 hours. I almost believe it because the tires are so new and the attachments look like they have never been used. Thanks for any help.
   / Can someone help me ID a PT? #2
   / Can someone help me ID a PT? #3
It looks like a PT1430 without a ROPS/Canopy to me. There should be a tag with a serial number somewhere around the driver's left knee(I think). A quick call to Power Trac with that number will confirm what model and year it is.
   / Can someone help me ID a PT? #4
I'd say an older pt1430 with no rops or quick disconnect.
   / Can someone help me ID a PT? #5
Good eye! It does not appear to have the quick attach. You would have to pin each attachment manually.
   / Can someone help me ID a PT? #6
I'll agree with the others it sure looks like an older pt 1430. You could probably call power trac and talk to Terry with the engine type and he could probably tell you for sure. Their phone # 1-800-the-yard.
   / Can someone help me ID a PT? #7
I assume you'll be selling it. What are you going to ask for this machine, if I may ask? I've been contemplating putting a T-8 quick attach on a T-12 machine, so I could use my existing attachments. This just might be a good candidate...
You can PM or email me if you'd like...
   / Can someone help me ID a PT? #8
It's a '97 near as Power Trac could tell me. No hydraulic quick attach.
   / Can someone help me ID a PT? #9
ddonnell, What attachments do you have for it?
   / Can someone help me ID a PT? #10
RegL
It's not mine. I called PT about it because I'm looking for one.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
UNUSED GOLD MOUNTAIN M202010 20'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
COFFING JLC / TON ELECTRIC HOIST (A51248)
COFFING JLC / TON...
