Can someone help? Bushhog zero turn PTO
   / Can someone help? Bushhog zero turn PTO #1
justtryin
I'm trying to take care of a farm and have zero experience. And, i'm a girl - no experience with mechanical stuff. Especially with this zero turn mower. it is stuck on a hillside as i write this. The blade dug into the hillside. i dug it out, but now pto will not disengage. i at least knew to check switches -- they are ok. Can someone help??
   / Can someone help? Bushhog zero turn PTO #2
Couple of guesses
The shock to the clutch may have jammed it. Is there a fuse or fuseable link somewhere? Maybe check the wires to the clutch and switches. Is the belt still on the pulleys? Did the sudden stop of the blades break the belt? Maybe just look at the drive system on the deck, does anything look broken or out of place? Be careful and good luck.
   / Can someone help? Bushhog zero turn PTO #3
Look under the deck to see if it is plugged with dirt, or the decki is bent into the blade..Only when the key is out of the ignition!! Be careful.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A55218)
2010 Ford F550...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52705)
2015 JOHN DEERE...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
