can someone explain the difference.....
   / can someone explain the difference..... #1
MeadowStoneFarm
CONENCTICUT
...between Yanmar series, like the YM/F/FX/YMG. How is a newer FX different than an older YM?
also i am in the market for one of these tractors. i'm located in ct, haven't had much luck finding dealers aorund. anyone know of a good one near me? all i've found is a place called zephyr knoll farm in ny.
   / can someone explain the difference..... #2
I could be wrong but think the F and FX are the same except for the power shift on the FX.
is the power shift similar to a shuttleshift? i have a ford 555 with a shuttle shift and i'm not impressed with it. anyone know if it puts more were and tear onthe clutch?
   / can someone explain the difference..... #4
power shift is like an automatic transmission in a car .I don't know if it's the same as shuttle shift. You can get power shift on a ym.
   / can someone explain the difference..... #5
Power shifts have fluid clutches as does power shuttles. A fluid clutch takes forever to wear out. They will out last many dry clutches. The difference between a power shift and power shuttle is that with a PShift you can change directions or shift gears without clutching. A PShuttle only changes directions without the clutch. With a standard or regular shuttle you have to use the clutch for everything and it is a dry clutch.
   / can someone explain the difference..... #6
To my understanding, YM's are grey market, FX's are American sold.. May be wrong, but thats the way I understand it.
so can anyone recommend a dealer that is in new england?
   / can someone explain the difference..... #8
That is not correct. All are Gray except the old 3 number models. Like ym240. F are from late 80s early 90's. Most have more of a step through floor. I prefer the oldies but I would not hesitate on an f or fx. I don't really know what the x stands for. It may mean powershift? Late 90's 2000's are k or ke like ke200 etc... Not too many of them here but some...
I am not an expert like the dealers on this forum are...
   / can someone explain the difference..... #9
Jerry is correct, I should have explained a little more . On power shift you can change gears & go to reverse without the use of the clutch.I have power shift on my 3110D.
   / can someone explain the difference..... #10
Re: can someone explain the difference..... *DELETED*
Post deleted by pruntyc
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
CASE IH 2412 - 12R CORN HEAD (A51247)
CASE IH 2412 - 12R...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
