Box Scraper Can someone explain a "rollover" box blade / scraper
   / Can someone explain a "rollover" box blade / scraper #11
Brian,
I defer to your superior experience.
You are correct, I was comparing them to construction grade boxes, not the home owner class ones. They are much better built than them. I guess I compared them the way I did as the construction grade ones are in the same price range as the roll overs. Right or wrong, that's what I did. Glad to hear your's is working so well.
One point, I can drop the scarifiers, drag the box full and have the rear hinged blade fixed. In that configuation it will pulverize soil, pile it up in the box and leave a smooth finished surface in one pass. (Well, after the sod has been removed.) And you are sooooo right, being able to pull a lever and have the scarifiers pop up out of the way is a treat! Must be even nicer with the roll over.
Cheers!
jb
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
2015 Ford F-350 Service Truck (A55852)
2015 Ford F-350...
2013 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2013 FREIGHTLINER...
2016 Jeep Wrangler Unlimited SUV (A55853)
2016 Jeep Wrangler...
