Can radial tires be mixex with bias
   / Can radial tires be mixex with bias #11
Have not done it yet just thinking about it. Rears are 16.9 x 30 fronts 11.2 x 24. I do very little road running and not over 15 mph if I do and if so no more than1/4 mile at a time.
Yeah Mark assumed you already mixed them in that first post. :)
You'll have no problems as long as the rolling circumference is similar. They will be similar as long as you don't change sizes. I don't think you'll notice any difference.
   / Can radial tires be mixex with bias #12
Its an interesting question, there are so many aspects to it depending on the type of vehicle, two wheel drive or four wheel drive, type of centre differential, and where and on what surface its driven especially with a locked centre diff.
One thing to think about is that most if not all radials these days have a steel belt to give vastly improved sideways stability to the tire. Now think about that for a moment. The steel belt cannot stretch or change length under high or low air pressure. The tire circumference does not change. It does look awfully flat at the bottom with less air, but the rolling circumference does not and cannot actually change.
On a low speed 4WD tractor I would think fitting the same sizes as the recommended factory originals would be all you need to worry about.
On a high speed road car, radials and cross plies have completely different handling characteristics.
Definitely the same type on the same axle, but you can mix fronts and rears, but its probably not a very good idea.
If you must mix front to rear, then always the radials must go on the back no matter which wheels are the driven wheels.
The reason for that is that at the limit of adhesion the radials will always grip better and hang on for longer assuming good tread and a dry road. The cross plies roll onto one shoulder and then let go suddenly.
If it breaks loose at the front you go off the road facing forwards, and may still have some limited control (understeer). You crap your pants, but at least you and the car probably survive the experience.
If it lets go at the back (oversteer) the car will spin and an inexperienced driver will immediately become disoriented traveling sideways or backwards off the road with absolutely no control at all.
A controlled crash is always better than an uncontrolled crash.
You might just be able to avoid the steel pole or concrete wall at the very last moment if you are still traveling forwards and can see ahead with some minimal control of direction.
   / Can radial tires be mixex with bias #13
Not exactly. Radial tires have much softer vertical spring rates and ride better as a result. They usually have quite a bit higher cornering stiffness because the sidewall, bead area and belt package [as we call it in the industry] structures are reinforced differently. Because of this they also have much less self aligning moment (like 10 times less). This is recognized by the lack of steering wheel returnability. Also because of the soft sidewall, they have very little camber stiffness. The end result is the dangerous practice of 'intermixing' the two types. A vehicle not designed for radials will have a very high steering gain and little steering feel, and a slow response initial response and settling time.
This is why tires named or referred to as 'racing radials' are not radial construction. To prove it, we burn them or slice them and examine the cord angles. Just the thin sidewall alone severely reduces the puncture and damage resistance of the tire. Not a good situation at 180+ mph.
Yes I worked in the industry.
BTW, this is also why a sidewall nick or cut repair is forbidden at all reputable tire shops. Too much flexing for a patch to contain and still be durable and not self destruct from strain and heat cycles.
   / Can radial tires be mixex with bias #14
Yes they ride more softly with softer vertical rates because the sidewalls are made much thinner (much lower ply rating) than cross plies.
They have exceptionally higher cornering stiffness and much lower slip angles because the steel belt under the tread is exceptionally stiff in shear.
Self aligning torque (of the steering) comes from a built in deliberate front end caster in the front end geometry, not from the tires. A shopping trolley can have solid wheels, and all four wheels self steer and align themselves perfectly with whichever way you push the trolley. Bicycles self steer too, you can ride without touching the handle bars and the front wheel self aligns. Nothing to do with the type of tires.
Yes you are quite right about racing radials.
   / Can radial tires be mixex with bias #15
That's not true, either. Self-aligning torque comes primarily from the twisting of the belt, sidewalls and beads. It's actually due to a fore/aft force distribution across the tire. Caster is added for several reasons. It adds a lateral force component to the tierod and steering rack which adds some effort/feel and returnability. It also aligns the tire's peak force from load and slip angle with the tire's peak aligning moment. Otherwise, at extreme sideforce/ cornering levels, the aligning torque starts to reverse and can go negative. That 'feel's all wrong to most drivers. I personally know that some race drivers can NOT trust their car's sidebite capability unless this is done. It does cut down the max grip level slightly but adds to a driver's confidence.
Your caster wheels are solid metal or plastic. Very little deformation possible to develop an aligning moment, hence the necessary high caster setting.
Here's my job in action: Tire Force Test - YouTube
The squeal is a high pressure supersonic air bearing under the roadway belt. This is a production SUV tire undergoing a simulated vehicle rollover maneuver. Doesn't even loose air, (as required ).
That's why we run tests, computer models and road measurements
   / Can radial tires be mixex with bias #16
Feels all wrong to most drivers, definitely have to agree.... Its terrifying.
That is very interesting about aligning torque reversing at very high force levels. I may have personally experienced that on the race track a couple of times, and its a truly frightening effect. Never understood how or why until just now, but you can be cornering very hard, and suddenly the steering tries to go full lock with enormous force.
Anyhow, caster definitely effects straight line stability, braking stability, as well as off centre steering loads (and feel).
Under those conditions there is not a lot of cornering force, if any at all. And we still need sufficient self aligning torque, and the belts in the tires are not going to provide that when steering straight ahead.
   / Can radial tires be mixex with bias #17
Great stuff. If we were on an auto forum. Not sure what any piece of it has to do with a tractor? :rolleyes:
   / Can radial tires be mixex with bias #18
All that matters to tractoring is the effective rolling radius. But, the manufacturer may have already built in an optimum front/rear slip ratio to give the best traction for pulling taking into account the type and pressure. If you change this, then drivetrain strain and traction reduction is likely.
For loader work, since radials 'squish' more and the wheels may not have been designed for radial tire bead forces, there may be airouts, blowouts, and bent rims (outward) resulting. Some operators stretch the limits and those are usually the ones that are the loudest on forums complaining about 'bad' designs, quality, cost of parts and disappointment with their purchase. Foreseeable misuse of anything these days is a crisis in any product development cycle. That's another reason so many companies have left the States. You can't fight them overseas.
   / Can radial tires be mixex with bias #19
Got to disagree with that statement.
   / Can radial tires be mixex with bias #20
This is much debated.
Warpspeed is correct in the sense that the distance around the outside of the tread does not and cannot change.
With that given, wouldn't it be logical to assume the distance traveled with each revolution remains the same? Even though the sidewall has bulged and shortened the tire height if measured from the ground up to the top of the tread?
This fact is what made Radial tires so popular. The radial design keeps the circumference from changing. This design makes the tire roll much easier because of a lack of distortion on the tread face. Thinner, softer sidewalls take care of the "squat" or "bulge". The sidewall requires much less HP to flex than the tread would.
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2022 CATERPILLAR 289D3 SKID STEER (A60429)
2022 CATERPILLAR...
John Deere 4600 (A53317)
John Deere 4600...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
