I think an hour and fifteen minute drive will end up being significantly faster than loading, securing, etc along with the heartache that goes with it
I have a 08 Titan and would not hesitate to put 9,500# behind it. Like others said the first thing is to make sure you are set up with brakes. The second is you will need a draw bar and 2 5/16" ball, and the third is you really need a WD hitch but that short of a trip you can get away with out it.
I pull 7,500# with mine 150 miles each and every weekend from May to October with no issues and have towed 11,000# once to help out a buddy with a broken Diesel Suburban.
Chris
you guys have alot more courage and or guts then i do. I would never pull a 10,000 pound trailer on a half ton truck. Now matter how many people say they have done it just fine.
We have a 13,000 pound camper that i pulled with a 3/4 ton 78ford with over loads, bumper hitch and it needed torsation bars and sway bars. It was still a job to drive that
We recently upgraded to a 3500 dodge drw and you dont need anything to pull the camper now. No load hitch or sway bar needed.
The one day, i had 12,000 pounds of hay on my hauler and my 3500 pulled it like it wasnt back there. That was with 5000 pounds of tounge weight approx. figured i had 8bales on a 6place trailer 6 in front of the axle 2 in the rear. Down to 4 bales that werent counter balanced. That was a normal just pin draw bar, and i dont have a spring loaded hitch on my truck. I want one how ever.
How ever if i were you guys i would be upgradeding to a bigger truck if i was to haul that much weight even more then once.
The 1/2 ton trucks of today are equal to or better than the 3/4 ton trucks of the 80's. I have had 2 3/4 ton trucks and 3 1 ton SRW trucks and 7 1/2 ton trucks and I can tell you the get stronger and better each and every year.
I would not hesitate to haul that load with any make of 1/2 ton truck but thats just me. Heck, I am not scared to put 25,000# behind my 2006 F-350. I would not head out across the country like that but locally or a few hundred miles would not scare me. I guess its a comfort level thing. I have been towing 10,000 miles or more a year for the last 20 plus years.
Chris
On my 3500 dodge i am not afraid to hull that much weight either. I have just seen to many half tonne trucks with their front wheels almost off the ground trying to pull @ 65mph
