Can my 4100 handle thisWoods brush cutter?
   / Can my 4100 handle thisWoods brush cutter? #1
ted5487
Boston
I own a John Deere 4100 Hydrostatic. I found a Woods Brush Bull BB48 for sale locally. The owner used it once on his Kubota and found it to be too big. I looked on the Woods site and it recommends this model for 15hp and up tractors. I think my tractor has 19 hp and 17hp at the pto. The brush bull weighs 509 pounds. Am I pushing the limits of my tractor? Does anyone have an opinion on this cutter? I will only be using the cutter occassionally around my property. Thank you.
   / Can my 4100 handle thisWoods brush cutter? #2
I've run a 60" brush hog behind my previously owned 4100 hst. It ran it just fine. There was times when I had to slow down due to the amount of material being cut, but I never felt like it was too much cutter. I should note that I had the loader In place when mowing for some counterbalance. If you don't have a loader I'd definitely look for a way to add some weight to the front. I know JD makes weights to fit the, but they may be pricey.
In short, plenty of power, go the appropriate speed, and add weight to the front. You'll be fine.
   / Can my 4100 handle thisWoods brush cutter? #3
I have the same cutter that I use behind my 2520. I know they aren't the same tractor, but I have no problems whatsoever, doesn't seem too heavy for the tractor and doesn't bog it down at all. I think you'll be fine, just take it slow through the heavy stuff as the previous poster suggested.
   / Can my 4100 handle thisWoods brush cutter? #4
I think you will be perfectly fine as long as you have a loader installed or front weights.
   / Can my 4100 handle thisWoods brush cutter? #5
I run a 48" LX4 at 400# behind my 4010, which has about 2 hp less than the 4100. I almost always run with the FEL in place. Removed just the bucket one time. Balance was still okay.
Ralph
Thank you to everyone for the quick replies. I purchased the brush cutter and plan on setting it up tomorrow.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2019 Nissan Versa Sedan (A50324)
2019 Nissan Versa...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
1263 (A50490)
1263 (A50490)
