Can Loader Arms be Straightened?
   / Can Loader Arms be Straightened? #1
westmich
Fruitport, MI
Kubota B2301
I have a Kubota B2301 with loader. Not sure how or when but the right arm appears to be bent down and in. I didn't really notice it until I took the bucket off and had to put it back on. If I measure the top of the end of the arms (the part that slips into the bucket) there is nearly a two inch difference in height between the arms.
Thanks
   / Can Loader Arms be Straightened? #2
Rear tire wear, rear tire inflation, loader mount frames, loader attaching hardware and levelness of your floor all affect your measurements and level bubble. Be sure your loader boom is actually tweaked. An auto body shop with a frame machine can straighten the boom if it is in fact twisted.
   / Can Loader Arms be Straightened? #3
You guys must live in a different world in so many respects. Any body shop big enough to have equipment like that, would NEVER work on a tractor loader here. Most, here are over worked with highly lucrative auto (insurance) jobs.
   / Can Loader Arms be Straightened? #4
My loader frame has gotten tweeked a bit in the past, mainly while stacking snow. When it does I just hook the high side of the bucket under a snow bank and tweek it back.
   / Can Loader Arms be Straightened? #5
Where I am in SC I don't know of anyone that straightens frames to any extent anymore. I know of a half dozen places that have frame machines that haven't been used in years. Not a lot of frame cars anymore. But the junk yards are full.
   / Can Loader Arms be Straightened? #6
I felt fortunate that the local body shop entertained the idea of painting the tailgate of my MULE, and possibly only did so because I had my vehicle in there at the time. BUT, they sure charged enough!
Someone that even has the mechanical capability would surely stay away from such a job anyway for fear of breaking something or making it worse. I know I wouldn't dare.
   / Can Loader Arms be Straightened? #7
Mine also went out of wack.
Turned out to be elongated FEL mounting bolt hole that was elongated.*
Moral of story is to check torque on all mounting hardware from time to time.
* cure is to bore oversize and add new sized bolt, or weld and re bore, ( I went oversize taking the easy way.)
   / Can Loader Arms be Straightened? #8
View attachment 673166View attachment 673167
Thanks
If the bucket came off easy and went back on easy, it is not the arms, but the bucket is twisted. I beefed my bucket up with 3/8th inch angle iron on top and 3/8th inch side plates welded on before I used it much. They are easy to twist, even after beefing up.
If it really bugs you, just find something real heavy and try to lift it with just the left corner of your bucket. It might even been just wear in the loader curl linkages. Try lifting the front tires of the tractor up with the bucket's joystick. I bet the cutting edge will go flat on the floor.
hugs, Brandi
   / Can Loader Arms be Straightened? #9
Just use it per normal. Mine was tweaked and by using it it tweaked back in place. It was so bad I couldn't even connect my quick connect attachments.
Over time it fell back in place.
Just lifting this heavy and crooked with twist it but it will eventually twist back when you lift something heavy on teh other side of the bucket.
   / Can Loader Arms be Straightened? #10
I am like others, your arms might not be bent.
Frame machines at auto body shops are used on modern unibody cars also, for whatever reason they still call them frame machines and I also doubt they would work well on a tractor.
LOT LOCATIONS (A52576)
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
