can I use this TSC valve for front remotes
   / can I use this TSC valve for front remotes #1
italianstallion69
PA
Kubota L2250
I need front skid steer style q/c on myloader to power hydraulic attachments.
can I use this chief 1 spool valve?
Chief 1 Spool Hydraulic Control 3 Way or 4 Way Valve - Tractor Supply Co.
I will come out of factory loader from the power beyond---into new valve inlet --- from new valve out to existing tractor power beyond outlet line to 3ph.
I also need to come out of new valve from OUT port and t into tank return from loader valve?
I cannot tell if there are only 4 or 5 ports on this.
Will this work?
Is the port with the hex cap blocking it off a power beyond port, I am assuming?
Thanks
   / can I use this TSC valve for front remotes #2
You can use this valve for certain things, but if used with a hyd motor, install a double relief valve across the motor.
Reason is that if you have a high centrifugal force like on a hyd bush hog, and you release the spool lever, that spool is spring centered, and will instantly shut down the work ports. The bush hyd motor now tries to act as a hyd motor and there is no where for the fluid to go. The double relief valve will safeguard the motor by causing the flow to recirculate.
As far as PB,
It says, Includes conversion adapter, but this could be conversion to closed center or PB.
Usually PB adapter is installed, and if you need closed center, you plug the PB port.
If PB is avaliable, that line will go to 3pt, and OUT/tank hose goes to tank.
I got the baileys valve with power beyond.
How do i plumb this up?
P on valve will be connected to power beyond out from loader valve. T on valve will goto power beyond IN? Do i not need to use N blocked off port? It has a hex plug of sorts.
The hydraulic motors are hi torque low speed auger and rockhound motors running thru a set of 1/2 skid steer q/cs.
Thanks!
   / can I use this TSC valve for front remotes #5
If the valve has the PB adapter or the hex screw, then you install the loader PBhose into the IN port of the new valve.
Tank port goes to any tank line.
PB from the new valve will go to the 3pt in port.
2013 INTERNATIONAL REEFER TRUCK (A54607)
2013 INTERNATIONAL...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
Scag Mower (A50324)
Scag Mower (A50324)
2019 MULTIQUIP WHISPERWATT PORTABLE GENERATOR (A51406)
2019 MULTIQUIP...
2005 Ford F-750 Truck (A55788)
2005 Ford F-750...
