Can i use another Tractor for weight on the Rear?
   / Can i use another Tractor for weight on the Rear? #1
deere4320
Northwest CT
2008 Deere 4320 eHydro w/400X FEL and Unloaded R4's
Hi All,
I found i set of 3PH forks i am very interested in. On my 4320 i have unloaded R4's, and when i try to lift something heavy i always get a little worried and i would like better traction. For loader work if i strapped the old wheel horse down on the forks (it weighs about 700 pounds) would i find better traction? Or would the only ways be a ballast box or filling the rear tires?
   / Can i use another Tractor for weight on the Rear? #2
Weight is weight, you will definitely notice the difference with the weight on the rear. It might be a little awkward depending on the size of the tractor but that is the recommended amount of ballast (700lbs) for most tractors.
I notice when I take off my backhoe and just have the boxblade on the rear, I can lift the loaded R4 tires off the ground when picking up something heavy. Also, I loose traction much faster and it will dig to china if I stay on the pedal.
Here's a funny video from a poster here on TBN that lifted a buddies tractor with his 3pt hitch then lifted another with the loader at the same time. :D
YouTube - Man Lifts Tractor
   / Can i use another Tractor for weight on the Rear? #3
Seems like you could find something better/safer then another awkward tractor, maybe a barrel full of rocks?
   / Can i use another Tractor for weight on the Rear? #4
Hi All,
The rear forks will work well for ballast. Piling anything on them or on a pallet will balance the FEL. 700 pounds should be enough to do the job since it will be well behind the rear wheels.
I use the rear forks for hauling a pallet with a large generator, welder, and air compressor. The front wheels will barely stay on the ground with my Kubota BX2200.
   / Can i use another Tractor for weight on the Rear? #5
Yea, do a search here. Many have made ballasts from a barrel of cement with a rod stuck through to engage the 3 PH arms.
   / Can i use another Tractor for weight on the Rear? #6
If I,I'd bite the bullet have tires loaded.
If you had project etc. and forks w/weight could be a pain..even w/tires loaded you could add on more home made rear ballast need be.
"i strapped the old wheel horse down on the forks"
Straps/chains can loosen,sure dislike the thought of backing over such rear weight you planing on using. :(
   / Can i use another Tractor for weight on the Rear? #7
Remember to consider where the center of gravity is going when you ballast. Lower is better, especially when ballasting for FEL ops. Also, make sure the ballast is well secured - nothing worse than a moving CG to throw you on your side.
-Jim
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2013 KENWORTH T800(INOPERABLE) (A53843)
2013 KENWORTH...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
