Mowing Can I use a MF1260 with a NH474 haybine
   / Can I use a MF1260 with a NH474 haybine #1
ricesinice
Hadley, ma
MF 1260
Hi All,
I just bought the farm. We now have a Massey 1260 that is supposed to have 33hp at the pto. Is this enough power to run the 474 haybine?
I really can't find any information about this searching online.
Thanks in advance for your thoughts.
Rob
   / Can I use a MF1260 with a NH474 haybine #2
How hilly is your property? Reasonably flat ground you should have no problem with 7 foot haybine. On hills concern would be tractor weight so the haybine doesn't push you around.
The land is pretty flat with just one hill with ledge that I want to see if the 1260 can wheelie over! I can probably work around it pretty easily. Thanks for the reply, hopefully I will be trying it out this weekend, and the loaded rear tires should help.
Well, purchased a NH 473 Hayliner and this guy did quite nicely on the test run on .5ac. the other day.
Semi with Box Bed (A55973)
Semi with Box Bed...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
TANK MANIFOLD (A58214)
2015 NISSAN Pathfinder (A56859)
2015 NISSAN...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
2019 Ford F-550 4x4 Crew Cab Utility Flatbed Truck (A55973)
2019 Ford F-550...
