Mowing Can I use a MF1260 with a NH474 haybine
   / Can I use a MF1260 with a NH474 haybine #1
ricesinice
Hadley, ma
MF 1260
Hi All,
I just bought the farm. We now have a Massey 1260 that is supposed to have 33hp at the pto. Is this enough power to run the 474 haybine?
I really can't find any information about this searching online.
Thanks in advance for your thoughts.
Rob
   / Can I use a MF1260 with a NH474 haybine #2
How hilly is your property? Reasonably flat ground you should have no problem with 7 foot haybine. On hills concern would be tractor weight so the haybine doesn't push you around.
The land is pretty flat with just one hill with ledge that I want to see if the 1260 can wheelie over! I can probably work around it pretty easily. Thanks for the reply, hopefully I will be trying it out this weekend, and the loaded rear tires should help.
Well, purchased a NH 473 Hayliner and this guy did quite nicely on the test run on .5ac. the other day.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2023 JOHN DEERE 333G SKID STEER (A51242)
2023 JOHN DEERE...
