Can i use a John deere mx-8 on a l5740?
   / Can i use a John deere mx-8 on a l5740? #1
fluffers
nh
none
Guys just found a 5 hr old mx-8 semi mount that I can get for $3500- Is that a good match for the 5740?
thanks for the advice for a newbee!!!
   / Can i use a John deere mx-8 on a l5740? #2
It looks like you can, PTO HP minimum of 40 HP and you have 50 HP. Weight won't be an issue as it is semi-mount. Go to the Land Pride web site, check L Series and it will show you suitable cutters then compare with the MX8, looks like it will be OK.
   / Can i use a John deere mx-8 on a l5740? #3
Don't see why not.
   / Can i use a John deere mx-8 on a l5740? #4
yeah, you'll be fine with that combo.
   / Can i use a John deere mx-8 on a l5740? #5
I have JD MX8 mower. Mine is mounted and very heavy. I initially mounted it on JD 4020 (95 HP). Under most conditions the tractor handled the load just fine but in tall, wet brome, the 4020 had a load. I have switched the mower to an IH 1486 (160 HP). That mower needs horsepower and I think it would be to much for a 50 hp tractor unless used for only short, turf type grass. I have a JD 6 foot mounted mower that I use behind a New Holland TC35 (35 hp) and that mower loads the New Holland in thick tall grass. Possibly a better match for your tractor would be the MX7.
   / Can i use a John deere mx-8 on a l5740? #6
The price for the MX8 appears ball park if condition good.
   / Can i use a John deere mx-8 on a l5740? #7
I had a Rhino tw96 that I ran behind a L4200 glide shift. Did just fine. Sometimes heavy grass would slow it down and I would have to raise it a bit. If you have any issues with power, and I don't think you will, just slow down/raise the mower a bit/sharpen the blades a touch or all three.
Allis Chalmers Snap Coupler Subsoiler (A49251)
Allis Chalmers...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A45679)
1993 INTERNATIONAL...
6000LB Axle (single) (A49251)
6000LB Axle...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
Tooth Bar (A49251)
Tooth Bar (A49251)
BT360 Stand on Skid Steer Loader (A49251)
BT360 Stand on...
