Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles.
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #1
Yoopertractor
Kubota L3710
Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I put my 4x6 poles??
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #2
Welcome to TBN.
We need to know more about the arrangement of boards and posts you want to use.
Bruce
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #3
@Yoopertractor if you are in the upper peninsula as your name suggests, the snow load for the area would also need to be known for the span.
My region has a 70 lb snow load and a 100 mph wind load. So securing the lumber for uplift is also a factor.
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #4
Once you know the snow load and the dead load (from roofing) and the span, you can find the required spacing and/or size of rafters from tables such as these:
https://awc.org/wp-content/uploads/2022/01/AWC_STJR2021_20201005_AWCWebsite.pdf
Typically you would use 8 foot spacing for 4x6 posts, but you could increase that somewhat for a small lean to. Unless you need larger openings, I would just go with 8 feet.
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #5
It all depends on the types of wood, span and size..
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #6
Snow load is 150lb here. Where are we located? What is code there?
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #7
Isn't it "build with what you have available or can get your hands on' anywhere north of the 75/127 split in northern Michigan? 😉
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #8
We need to know where you're located (snow load), whether you're using them as rafters or purlins, what distance they're spanning, whether you're using headers between posts with rafters resting on them or rafters bolted/resting to/on posts with purlins between them, roof pitch, how much of/if there is a roof above that may be sending snow onto the lean-to etc, etc.
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #9
Maybe sketch it, pencil & paper. Post a picture.
   / Can I use 2x6s for a lean-to type of roof with my 4x6x18' poles and how far apart do I need to put my 4x6 poles. #10
2006 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2006 ADVANCE...
2012 KENWORTH T800 SLEEPER (A45046)
2012 KENWORTH T800...
2020 PETERBILT 579 TANDEM AXLE SLEEPER (A43003)
2020 PETERBILT 579...
Towable Pump (A44571)
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A44789)
2010 Gleaner 9250...
Scissor Lift (A44571)
