Tires can I replace front tires w/1/2" smaller diameter on Kubota 4wd/hydrostatic?
   / can I replace front tires w/1/2" smaller diameter on Kubota 4wd/hydrostatic? #11
   / can I replace front tires w/1/2" smaller diameter on Kubota 4wd/hydrostatic? #12
Adding to this, while in 4x4 every time you make a turn, those said gears in the Tranny get loaded up, thus the need to only use 4x4 on loose surfaces. In other words, even with perfectly matched tires, you will still get wear if you drive in 4x4 on hard surfaces.
   / can I replace front tires w/1/2" smaller diameter on Kubota 4wd/hydrostatic? #13
A couple of points here. First, on these 4wd (technically front wheel assist) tractors, the tractor and tire manufacturers usually recommend a front/rear tire combination that results in the front tires leading, or covering more distance than the rears, by 0 - 6 %. Second, you want to avoid a lag situation, where the fronts travel less than the rears. If the front tires lead, they help to pull the front of the tractor in turns; if they lag, the rears are pushing the front slightly. Perhaps more importantly, a lag situation can cause binding in the drivetrain and may result in increased wear on its components. The worst scenario is a lag configuration operating in 4wd on a hard surface, which can result in severe binding, even going in a straight line. Obviously, if the 4wd is not engaged, there is no lead/lag to consider because the non-driven front axle simply matches the rolling speed of the rear axle.
To figure the lead/lag, you need to know the rolling circumference of each tire and the tractor's front/rear gearing, and then do some math.
There is some tolerance, such as to allow for tire wear. For example, suppose you had brand-new front tires and bald rears. Your fronts would lead more than if both sets of tires were new. Conversely, if the fronts were bald and rears had full tread, it would have more lag.
Since the tread depths on these tractors are quite a bit more than 1/2", the change in tire diameter the OP mentioned should not by itself cause an issue. Note that you should verify the manufacturers specified rolling circumference for the tire, not just the diameter. Depending on the gearing and tire rolling circumference, it might even give a better lead/lag than the OEM setup. And, you'd still want to estimate the lead/lag both with and without tire wear.
I am by no means any expert on this, but this topic was extensively covered by some TBN pioneers more than 12 years ago, whose discussions I followed at the time, and I hope this represents those discussions correctly.
   / can I replace front tires w/1/2" smaller diameter on Kubota 4wd/hydrostatic? #15
Grandad is correct, I also did a lot of reading on the issue as I needed to make changes up front due to trashed rims due to previous owner having used calcium ballast up front.
I lucked out with garden tractor rears that fit stud pattern as well as rolling diameter and as a plus were wider for better floatation.
In my case replacement rims were simply not available.
   / can I replace front tires w/1/2" smaller diameter on Kubota 4wd/hydrostatic? #16
I have always been told that 2.5% is the magic number when it comes to differences from 0 lead or lag.
In other words you can have up to 2.5% lead and you are okay. I agree with the people above. You don't want to be in a lag situation if you can help it. That just binds things up and causes the tractor to fight itself. When in doubt error towards lead.
What I have done with situations like this is to take the Overall Diameter (OD) of the rear tire and divide it by the front to get a ratio that is roughly the ratio of the gearbox. For example my little JD 3520 had a gear box that was a 1.623 to 1 ratio. Meaning that the front tires went 1.623 around to every one of the rear.
I got that two ways. One was I divided the front and back tires to get the ratio. Then I figured there would have been a little lead roughly 2% built into it, which there was. I then called JD to see if I was close, and they confirmed that I was.
In your case, I would try and see if I could find the actual ratio of the gear box and then get your ODs from your tires and see if that smaller one will work.
Just for clarification. The measurement from the center of the axle to the floor is called Loaded Radius. and the measurement of one revolution of a tire at a given load and pressure is called Rolling Circumference.
And as was stated previously, if you are only using your front wheel assist in wet conditions, and there will be ample slippage then you should be fine. Its just the binding in the turns or on dry pavement than could cause an issue.
UNUSED FUTURE MINI EXCAVATOR 8" HYD AUGER (A51244)
UNUSED FUTURE MINI...
Barn Wood Planter Box (A50515)
Barn Wood Planter...
UNSUED AGT MX-CRT23 STAND ON SKID STEER (A51243)
UNSUED AGT...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
2015 CATERPILLAR 299D XHP SKID STEER (A51242)
2015 CATERPILLAR...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
