Can I mix 2ply and 4 ply tires on 60" Z Force Mower
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #1
Saxbird
Mn
Cub Z Force L 60
I blew out a tire on my new 60" Z Force with only 10 hrs on it. Crappy 2 ply tires!!
Id like to replace that blown tire with a 4ply tire will it be ok to have a 2ply on one side and 4 ply on the other side since its not a solid axle I would think it would but want to know for sure?
Appreciate any help
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #2
Should be OK, but you can't keep them at the same PSI. 4 plys go to 20 PSI or so and 2 plys only go to 10. You will have to make sure they feel the same.
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #3
On a zero turn you won't notice much difference other than the ride unless they are radically different diameters.
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #4
Ride quality might not be noticeable but I have noticed that even a couple of pounds difference in rear tire pressure will make the cut uneven. You might have to experiment with tire pressures to get the running diameters the same.
1268 (A50490)
1268 (A50490)
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
New Holland Hay Rake (A51573)
New Holland Hay...
John Deere 6120E (A50323)
John Deere 6120E...
