Can I mix 2ply and 4 ply tires on 60" Z Force Mower
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #1
Saxbird
Mn
Cub Z Force L 60
I blew out a tire on my new 60" Z Force with only 10 hrs on it. Crappy 2 ply tires!!
Id like to replace that blown tire with a 4ply tire will it be ok to have a 2ply on one side and 4 ply on the other side since its not a solid axle I would think it would but want to know for sure?
Appreciate any help
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #2
Should be OK, but you can't keep them at the same PSI. 4 plys go to 20 PSI or so and 2 plys only go to 10. You will have to make sure they feel the same.
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #3
On a zero turn you won't notice much difference other than the ride unless they are radically different diameters.
   / Can I mix 2ply and 4 ply tires on 60" Z Force Mower #4
Ride quality might not be noticeable but I have noticed that even a couple of pounds difference in rear tire pressure will make the cut uneven. You might have to experiment with tire pressures to get the running diameters the same.
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
