Can I leave Mower on tractor Raised Long Term?
   / Can I leave Mower on tractor Raised Long Term? #1
ulflyer
lexington nc
CK 30H
My CK30 is parked under a shed but it gets a lot of dampness underneath on the ground. By leaving the finish mower locked in raised position it keeps it out of moisture. Any likely damage to tractor mechanism doing this?
   / Can I leave Mower on tractor Raised Long Term? #2
I’m looking forward to the coming responses!
   / Can I leave Mower on tractor Raised Long Term? #3
It will probably leak down and drop over time. Better to put blocks under the edges of the mower deck to hold it up off the ground.
It won't hurt the tractor though, as a later post said.
   / Can I leave Mower on tractor Raised Long Term? #4
It will slowly slowly leak down. I believe for the loader hydraulics Kioti says something like an inch an hour of sag is “normal”. Mine is nowhere near that bad and I have also kept the rear finish mower raised for several days with no sag but I would expect it to occur so place blocks under it.
   / Can I leave Mower on tractor Raised Long Term? #5
others told you other things but didn't answer your question. NO IT WILL NOT HURT ANYTHING
   / Can I leave Mower on tractor Raised Long Term? #6
I would simply block it up. However - it WILL NOT necessarily leak down. I have my 1100 pound Rhino 950 rear blade on the 3-point. It will remain in the full raised position for at least 45 days without dropping a measurable amount. Beyond 45 days - no empirical data on that length of time.
But - NO it will not hurt anything to leave it in a raised position.
Thanks folks. I left it raised throughout the spring/summer months, sometimes for several weeks and it didn't sag. Will see how it does long term. I don't have anything handy to prop it up with.
Edited: I close the valve under the seat that hold it up. Forgot to mention that. Sorry.
   / Can I leave Mower on tractor Raised Long Term? #8
I would think you could just shut the 3 point speed valve and it would not leak down . Happens enough to people by mistake .
   / Can I leave Mower on tractor Raised Long Term? #9
I often leave my 3 point raised with the 1200+lbs balast block on it and have never had it leak down.
   / Can I leave Mower on tractor Raised Long Term? #10
Don't do it with a hydraulic toplink. That will leak down and jam the deck into the PTO shaft.
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
2016 INTERNATIONAL PRO STAR TANDEM AXLE DAY CAB (A58017)
2016 INTERNATIONAL...
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: 132,994 Plate: Body Type... (A56859)
Year: 2014 Make...
2018 Kubota U17 (A53317)
2018 Kubota U17...
