Can I leave Mower on tractor Raised Long Term?
   / Can I leave Mower on tractor Raised Long Term? #1
ulflyer
Bronze Member
lexington nc
CK 30H
My CK30 is parked under a shed but it gets a lot of dampness underneath on the ground. By leaving the finish mower locked in raised position it keeps it out of moisture. Any likely damage to tractor mechanism doing this?
   / Can I leave Mower on tractor Raised Long Term? #2
I’m looking forward to the coming responses!
   / Can I leave Mower on tractor Raised Long Term? #3
It will probably leak down and drop over time. Better to put blocks under the edges of the mower deck to hold it up off the ground.
It won't hurt the tractor though, as a later post said.
   / Can I leave Mower on tractor Raised Long Term? #4
It will slowly slowly leak down. I believe for the loader hydraulics Kioti says something like an inch an hour of sag is “normal”. Mine is nowhere near that bad and I have also kept the rear finish mower raised for several days with no sag but I would expect it to occur so place blocks under it.
   / Can I leave Mower on tractor Raised Long Term? #5
others told you other things but didn't answer your question. NO IT WILL NOT HURT ANYTHING
   / Can I leave Mower on tractor Raised Long Term? #6
I would simply block it up. However - it WILL NOT necessarily leak down. I have my 1100 pound Rhino 950 rear blade on the 3-point. It will remain in the full raised position for at least 45 days without dropping a measurable amount. Beyond 45 days - no empirical data on that length of time.
But - NO it will not hurt anything to leave it in a raised position.
Thanks folks. I left it raised throughout the spring/summer months, sometimes for several weeks and it didn't sag. Will see how it does long term. I don't have anything handy to prop it up with.
Edited: I close the valve under the seat that hold it up. Forgot to mention that. Sorry.
   / Can I leave Mower on tractor Raised Long Term? #8
I would think you could just shut the 3 point speed valve and it would not leak down . Happens enough to people by mistake .
   / Can I leave Mower on tractor Raised Long Term? #9
I often leave my 3 point raised with the 1200+lbs balast block on it and have never had it leak down.
   / Can I leave Mower on tractor Raised Long Term? #10
Don't do it with a hydraulic toplink. That will leak down and jam the deck into the PTO shaft.
19008 (A48082)
19008 (A48082)
2011 Honda Odyssey Mini Van (A50860)
2011 Honda Odyssey...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
Iron Platform for Forklift (A50860)
Iron Platform for...
