Can I jury-rig hose
   / Can I jury-rig hose #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
I've had a mini backhoe from Northern Tool since 1990 (smaller than the one they sell now). It has worked well- ditches etc.. I replaced the 5 hp motor with an 8 hp Tecumseh. The 1.5 oil pump was replaced with a 2 stage 11gpm pump. I've split and twisted the leg support frame and had that re-welded. I snagged a hose and tore it ditching through trees and brush once. Today, after just replacing the carb and gas tank, it caught on the first choke pull, and ran strong on the next pull. It was outside all this time, and the weeds were thick as anything. I got it out, but then one of the hoses at the connection to the cylinder burst a nice leak. I'll probably go get another hose tomorrow.
But looking at the other hoses, they look a bit rough too at the cylinder connections. I have an old piece of hose. Has anyone ever jury-rigged a splice?
Or is there a coupler connection you can buy to join two pieces of hose?
I think I am going to run into some problems and I'd like to know my options and finish what I'm doing before running off for replacements!
   / Can I jury-rig hose #2
The hoses are over 20 years old and apparently have sat outside most if not all that time. Replace them, either all at once, or as needed. But replace them. Splicing 20 year old low-end hydraulic hose is a fool's errand.
   / Can I jury-rig hose #3
Fluid squirting at 2000+ PSI is nothing to play with. Either fix it correctly or scrap it.
   / Can I jury-rig hose #4
If you took the hose to a hyd shop, they probably would not attempt to fix your hose. There might even be a splice kit to fix certain hoses, but you would have to find the correct fittings to your old hose.
Best fix is to purchase a new hose for the one that split. You can purchase ready made or custom order for your splitter.
   / Can I jury-rig hose #6
How much does new hose cost?:thumbsup:
If that is a serious question. How much? Way more than one expects. I about had a heart attack when I bought them for my homemade splitter.
Harry K
It is nice to do things the right way, but sometimes that's too costly. The trick is to figure where the short cuts are reasonable. I met a man once who mounted his back hoe on the back of his truck. He also had an old tractor with the engine replaced with a 4 cyl car motor, transmission too. He had a lot of gear combinations. I knew a high school student who rigged up his John Deere pto to his truck body trailer differential to make a woods trailer for the snow and mud.
Sometimes it is nice to see a little less chrome and a little more purpose.
   / Can I jury-rig hose #8
Sometimes it is easier to see if you have not lost a eye to a high pressure hydraulic leak!
I like that! Good reason too.
   / Can I jury-rig hose #10
Here is a reasonable shortcut for you: buy standard-length pre-made
hoses, rather than going to your local hose shop for custom-made. Do
you know that you can buy a 30" long 1/4" hose for $10 from Surplus
Center? Buy all new hoses at one time and save on shipping. So what
if some of them will be a little too long.
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
CONTACT INFO (A53084)
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
