Can I fix my table saw motor?
   / Can I fix my table saw motor? #1
GGB
Kansas
John Deere 2032R, John Deere Z930M, John Deere 455, John Deere XUV825i w/Deluxe Cab & Roll Down Windows, Snow Blade
Another thread reminded me of a question I've wanted to ask for some time.
I've got a Ryobi woodworking table saw which served my needs very well, that is until I killed it trying to do dado cuts too aggressively. I just was taking too large a cut, and would have been fine if I'd just done an eighth of an inch or so at a tiem, but NOOOOO......I got in a hurry, and was taking way too much with each cut. Almost no warning before it quit. It really had handled the cuts up to the point it died. I had hoped it was just overheated, and that I could hit the reset button, but I wasn't that lucky.
So now I'm using it as an expensive router table, but sure would be nice to have it back working again for a new project I'm getting ready to start. Is it worth trying to fix the motor, or should I just cut my losses and buy a new table saw? I'm not afraid to tear it apart, but don't have much experience on electric motors other than replacing brushes, but I have experience rebuilding old generators, alternators and starters from cars. Thanks!
GGB
   / Can I fix my table saw motor? #2
Take it to a motor shop. They'll check it, rewind it or whatever.
   / Can I fix my table saw motor? #3
I just took apart my ryobi 3100 saw to seperate the aluminum from the steel for scrap. A new motor for this saw($224 + shipping) costs more than a used saw on Craigslist. I was pissed that an otherwise great saw was made worthless by a less than robust motor. I must admit I was able to use this saw for light work for 19 years but the design was flawed. As soon as people besides me started using it , it was doomed.
   / Can I fix my table saw motor? #4
Picture of the saw?
Does int have a separate motor and blade spindle, or does the blade mount on the motor shaft?
If the blade mounts to the motor, I would take it into a shop and have them work it over. You should be able to get it repaired. Our large (3/4 horse?) motor for the hay elevator stopped starting and we were able to get it rebuilt (including new bearings and a new pulley) for about $120
Aaron Z
The blade does mount to the motor. I'll try to get a picture of it a little later when I'm out at the barn. Thanks.
GGB
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
