Can draft control be added to a tractor ?
/ Can draft control be added to a tractor ? #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I only found out about draft control from one of the folks here.
Anyone know if it can be added to a tractor that didn't come with it? I have a Kubota L3400 that does not have it out of the factory. If it is possible, any clue what it would cost?
/ Can draft control be added to a tractor ? #2
i don't know the answer to your question but my tractor has draft control and it broke a few years back. it made it easier to plow but i don't have much trouble plowing without it.
/ Can draft control be added to a tractor ? #3
Its available as an option on many Kubotas. I would look at the brochure, the Kubota website, or call your dealer. I'm fairly sure it can be added to an L4400 but not sure abou the L3400.
/ Can draft control be added to a tractor ? #4
Draft control is an option on the L4400 I don't know about the other two.
/ Can draft control be added to a tractor ? #5
If you have enough time and money, nearly anything's possible. But I question whether or not such an investment would ever amortize. I'm thinkin' it would likely be much cheaper to just trade up to a tractor that already HAS draft control
//greg//
2006 Kenworth W900 Dump Truck, VIN # 1NKWLB0X26J138148 (A65563)
2006 Kenworth W900...
2016 International WorkStar 7500 T/A Dump Truck (A64556)
2016 International...
L-Shaped Fuel Tank Hose and Electric Pump (A62679)
L-Shaped Fuel Tank...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
BushHog 2615L 15ft Batwing Rotary Cutter (A65640)
BushHog 2615L 15ft...
