Can BX2360 stabilizers be changed?
/ Can BX2360 stabilizers be changed? #1
newdeal
The stabilizers on the 3pt hitch suck on the BX 2360...what a huge pain you basically need a wrench to tighten them and it takes forever. Is there any way to put something better on this tractor? I am considering having wing nuts welded onto the threaded portion so at least I can turn it tighter by hand but there must be a better way
/ Can BX2360 stabilizers be changed? #2
I assume that the telescopic ones that can be put on the B's will not work. They are standard on the B2630, but will fit the B's. I did not like the ones on my B2920 either, and put the telescopic ones on. Much better.
Stabilizer
Other than that, maybe go to a quick system. I put the Pat's system on mine and hardly ever made any adjustment. But even they work better with the telescopic stabilizers as they hold the lower arms apart when there is no implement on the tractor so you don't need to spread the lower arms apart. Also the telescopic allow for using the slotted holes when I want some play in the lateral movement.
2022 EZ-GO ELITE...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2022 EZ-GO ELITE...
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
