Can Anyone Identify This Weed
   / Can Anyone Identify This Weed #1
Shemp
Got them all over my land. Want to get rid of them. Any suggestions as to what chemicals to use. Something that wont effect my horses. Thanks for the help.
   / Can Anyone Identify This Weed #3
According to this plant that's called Hemp Dogbane Am I right??
   / Can Anyone Identify This Weed #4
Would help to know your general location. In my part of the world that is called Dove Weed or Texas Croton. Hi-Yield 2,4-D Amine No. 4 applied at a rate of 1-1/3 fl. ozs. per 1 gal. of water should do the trick, but it's probably to late in the year to waste the spray. Mow it down and hit it in the spring.
   / Can Anyone Identify This Weed #5
We always called it Goat Weed. It will spread rapidly and take over your pasture. Mowing generally keeps it in check if you mow to keep it from seeding out. 2,4-D will kill it but you likely need to keep your critters off when spraying with any type of herbicide. They used to make a wax bar impregnated with 2,4-D that you could mount on a spray boom and drag it over the tops of weeds rather than spraying.
Still need to keep animals off the pasture. Maybe section off the pasture with an electric fence and do half at a time, but again, short mowing will do away with them and allow the grass to fill back in. 3 or more times per year will keep most weeds in a pasture at bay without resorting to herbicides.
   / Can Anyone Identify This Weed #6
There is a liguid sprayed chemical called "Glyphosate", 41% working chemical, the exact formula as Monsanto's Round-up at about 2/3rds. the cost of Round up. Use maximum 6 ounces per gallon. Any more is a waste. Go to your county Extention service and they can advise you on when to spray, probably at least twice, once in the spring and once in summer. Check it out.
   / Can Anyone Identify This Weed #7
This will kill everything in your pasture too. ... Well maybe not resistant Pigweed. If you have that too, you have a bigger problem.
   / Can Anyone Identify This Weed #8
Yes, it can be used as a post and pre-emergent. The best thing is to go to your couny extension officer. The people are true experts and they know their area. This is why they are here. Also,look up The Noble Foundation. They may some info.
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
Electric Mobility Scooter (A51694)
Electric Mobility...
2020 Case TV450B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TV450B...
Brent 876 Grain Cart (A50774)
Brent 876 Grain...
New 3pt Sod Cutter (A50774)
New 3pt Sod Cutter...
2006 Isuzu NPR 16ft Box Truck (A50323)
2006 Isuzu NPR...
