Can anyone identify this snowblower?
   / Can anyone identify this snowblower? #1
newlife
Maine
New Holland TC35
It is 72" wide. I bought at a farm auction 4 years ago. It was doing great until last week when I twisted the yoke off the PTO input to the blower. It is an odd ball yoke. 1.5" in dia at the shaft input with a 3/8" key, with an addition factory installed 3/8" roll pin 90 degrees to the key. I checked Tractor Supply and some online places but no luck. I was hoping whoever built it was still around.
   / Can anyone identify this snowblower? #3
The implement yoke should be a stock part , 1-1/2 bore with 3/8 key is standard however the roll pin may well be factory fitted.
First you need to Identify the pto series usually determined by u- joint dimensions.
Dose this yoke have the shear pin joint also ?
It kinda looks like an early Meteor, Made by M.K.Martin in Elmira, Ontario
MK Martin | Meteor Snow Blowers
I am all set . The local driveline shop identified all the parts. Only took 3 days to get. All up and running again. I still am not 100% sure who built it. My Ford pickup did the plowing while the snowblower on the NH was out of commission. I am ready for spring. This winter started way to early and has not let up.
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
Fire Truck (A51692)
Fire Truck (A51692)
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
