Can anyone explain the pros cons of 3pt Versus 2pt linkage rotovators?
   / Can anyone explain the pros cons of 3pt Versus 2pt linkage rotovators? #1
Blagadan
Western Europe
Kubota B7100D
Hi Folks,
I am looking at buying a rotovator for my Kubota B7100. I have an option of buying a 2 point linkage rotovator OR a 3 point linkage rotovator...
The 2 point linkage unit is cheaper than the 3 pt.
What are the pro's and con's between the two?:confused:
thanks,
b
   / Can anyone explain the pros cons of 3pt Versus 2pt linkage rotovators? #2
Is one to assume that they are the same except that the 2-point does not connect to the top link? Does it rely on a tail wheel with some sort of mechanical adjustment for its height? It doesn't make sense that such an arrangement would be less expensive to produce than a 3-point hitch version. Perhaps you could provide more info such as manufacturers names and models, even links to websites to clarify the issue.
   / Can anyone explain the pros cons of 3pt Versus 2pt linkage rotovators? #3
I would get the three point tiller to attach to the top link of your tractor; otherwise transporting and getting proper use will be limited and may cause the tiller to bounce on hardened soil.
Also, if it is a two point it must have a stabilizing system with wheels or skids, and be awkard to manuever when using? The PTO connection on the two point system would be interesting also?
   / Can anyone explain the pros cons of 3pt Versus 2pt linkage rotovators? #4
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A53843)
2021 ALLMAND BROS...
2015 MACK CHU613 DAYCAB (A53843)
2015 MACK CHU613...
