Can anyone assist me
/ Can anyone assist me #1
AJ Hawaii
shenniu bison 254
I was given a Shenniu Bison 254 tractor it runs great a little cozmetics would do but thats minor, my main problem is this I can't get the three point to lift nor lower I have checked everything removing the oil line fittings to check if it's clogged so far so good, and neither can I get the PTO to engage, should the gear oil level be filled to max capacity, can anyone assist me?
/ Can anyone assist me #2
does it have a loader or any external hyds. and lines with cuick disconnect style fittings?
post a picture.
soundguy
/ Can anyone assist me #3
Can you describe your complete hyd system, and add some pictures if possible. Do you know for a fact that the pump is pumping fluid?
/ Can anyone assist me #4
And be careful disconnecting hydraulic line fittings, there could be 2000psi (or more) of oil pressure in them!
Have you checked to see where the rockshaft valve (for rate of descent of attachment) is set at??? I assume it has one?
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
Hydraulic Fire Plow Attachment (A61572)
Hydraulic Fire...
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
