can any one send me a wiring diagram for the 4310
   / can any one send me a wiring diagram for the 4310 #11
They make the controler difficult to access on purpes as they almost never go bad . its usualy a wiring problem or bad connetor .
What happend? should be a code flashing on the rh fender switch panal near the fwd switch and pto switch. will be a series of long and short flashes . that should help to point in the right area. dont start screwing around to much or you can just make things worse. make sure the seat switch is working , if its a hydro check the forward/revesre pedals to be sure they are returning all the way to the top, Ive seen a stick knock the conector off the throttle sensor , (near the injection pump) good luck.
I could answer your questions if the manual covered my tractor but changes were made to the 4310 after the manual I bought with the tractor was printed, so the wiring doesn't match what's in the manual
   / can any one send me a wiring diagram for the 4310 #13
Ok, is there no codes at the rh fender indicator light? on the early 4000 tens the lite was actuly inside the fuse box area just laying there atched to a couple wires. forget about the book for now, just trying to help you get moving again:)
there is one code that pertains to a part that was deleted from the 4310 and my tractor according the the manual I have so it must have a different meaning on my 4310
and the wire colors are different
   / can any one send me a wiring diagram for the 4310 #15
Flywheel speed sensor your saying ? I think they elemenated those. controler reads off the tach signal from the alternator on those I think. I guess with out the right book it will be tough. good luck.
yup
the manual I bought to work to work on my tractor doesn't cover my tractor
I think jd owes me a manual that covers my tractor
I paid for it in good faith
I have to cowling off so it's in the open
I just need to know what wires to check for what signals
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55218)
2008 Ford F-250...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
1996 JCB 506B Telehandler (A55218)
1996 JCB 506B...
