can any one send me a wiring diagram for the 4310
   / can any one send me a wiring diagram for the 4310 #1
chickenman
when i bought my 4310 i bought a manual to work on it but the manual didn't cover my sn#
and changes were made on the 4310 that the manual doesn't cover
i need the wiring diagram for the drive controller for an ehydro and test procedure for calibrating it
this is an emergency to me as now my tractor wont move at all and i need it , i have a horse farm
deere is closed till monday
also does anybody know how i can contact deere directly?
the sn# is lva4310h330143 so i need a manual that covers from that sn# forward
i bought it in march of 2004
   / can any one send me a wiring diagram for the 4310 #2
Have you been on jdparts? Off hand don't know if the schematics are there or not.
I'll see if I can find some time to find it on my CD tech manual.
Here is the Electrical Table of Contents. See what you are looking for? I didn't find the drive controller (yet). :)
jdparts just has parts drawings
i need to know what wires run where and what voltages and frequencies are there
went to a dealer and got a pile of printouts none of which give me the info i need
   / can any one send me a wiring diagram for the 4310 #4
I may not be any more help than the dealer. I posted the table of contents. See anything there to dig into?
someone with the latest manual on cd as pdf may be able to help
   / can any one send me a wiring diagram for the 4310 #6
Owners manual won't have it, you'll need the service manual.
Beenthere, what happened to your attachment ?, seen a few pages that could possibly help him.
i have the shop manual on cd but it doesn't cover my tractor
I was hoping for someone with a later revision that could send the electrical section to me
what attachment are you speaking about?
   / can any one send me a wiring diagram for the 4310 #8
I posted the table of contents in Post #2 above.
There are many pages of wiring schematics, and I'm not finding anything specific to "drive controller" so hoped the TOC would list something that would lead to something particular to look at.
If you see anything, give a shout. Not sure here what revision chickenman is looking for. Maybe mine is too old ??
we can start with 155, 151, 150, 139, 143
maybe those pages will match my actual wiring
is this from a paper manual?
and thanks
   / can any one send me a wiring diagram for the 4310 #10
What happend? should be a code flashing on the rh fender switch panal near the fwd switch and pto switch. will be a series of long and short flashes . that should help to point in the right area. dont start screwing around to much or you can just make things worse. make sure the seat switch is working , if its a hydro check the forward/revesre pedals to be sure they are returning all the way to the top, Ive seen a stick knock the conector off the throttle sensor , (near the injection pump) good luck.
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
