Can a wood chop saw bw used for metal cutting?
   / Can a wood chop saw bw used for metal cutting? #1
hz293
Kalama,WA
Kubota B7510HSD
I have a HF 12" sliding chop saw that I don't use alot. If I put a metal cutting disk on it will it work for cutting metal?
Harris
   / Can a wood chop saw bw used for metal cutting? #2
Certainly....................... but
doubt that it will last very long or work very well.
HF sells metal cut off saws for not much $$$$. I'd go that route.
ron
   / Can a wood chop saw bw used for metal cutting? #3
Harris
Are you refering to an abrasive metal cutting blade or a carbide tipped cold saw blade? DO NOT install a carbide tipped "cold cut" metal saw blade on your 4500-5000 + rpm miter saw. Those blades are all specifically designed for low rpm ie.1500-1800 rpm. An abrasive blade would work but a cheap chopsaw with blade can be had for about $50.00 and your top-o-the line DeWalt will stay in mint condition.
   / Can a wood chop saw bw used for metal cutting? #4
NO!....
   / Can a wood chop saw bw used for metal cutting? #5
Afternoon Harris,
A regular chop saw goes to fast. At work we use a Porter Cable metal chop saw 14" blade rated at 1600 rpm. Thats the right tool for the job. You might get away with it for awhile but I doubt it will last :( On ours, we have the support stands on each end along with adjustable stops. It is a neat setup.
   / Can a wood chop saw bw used for metal cutting? #6
With all the grit that ends up on my chop saw, I would not even consider doing it with my mitre saw. And on my metal chop saw, if I saw a heavy or thick piece of metal, I sometimes get a glowing red "icicle" at the back edge of the shield where most of the metal bits hit.
Thanks for the quick comebacks. I bought a 14" HF Metal cutting chop saw and will save my wood one for wood. Thanks everyone....
Harris
   / Can a wood chop saw bw used for metal cutting? #8
I think that would be a bad idea. I ahve a cut-off saw, but rarely use it now that I have a portaband. That is the tool for the job when it comes to cutting metal.
   / Can a wood chop saw bw used for metal cutting? #9
Harris
hz393 you made the right choice. You wont regret it.
   / Can a wood chop saw bw used for metal cutting? #10
I made just a couple of cuts with my Makita miter saw before I ran to buy a Milwaukee chop saw for steel.
More tools are better anyway....... :eek:
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
