Can a Kubota L2501 move a round bale?
   / Can a Kubota L2501 move a round bale? #11
I have an L2501, I use it for logging. I think you could lift 1200 pounds off the ground for transportation however that would be it. So if your getting bales off a stack, that would be too dicey.
Bales are sometimes wet, hence heavier.
When bale is speared at least half, probably 60% of the weight will be above the spear. The front wheels crossing a rut or dropping into a depression could fairly easily roll a L2501 in this inherently unstable condition.
Safety first.
If you are only going to have 2 cows and they are grazing on 3 acres how much hay do you need? Would round bales "go bad"?
Great question. Im learning as i go here. lol
   / Can a Kubota L2501 move a round bale? #13
When bale is speared, at least half, probably 60% of the weight will be above the spear. The front wheels crossing a rut or dropping into a depression could fairly easily roll a L2501 in this inherently unstable condition.
Safety first.
Not if the bail is just off the ground. The bail would hit the ground preventing rollover. Work smarter....
   / Can a Kubota L2501 move a round bale? #14
Safety first.
Also, if your careful, and like the OP only handling a few BALES, you could probably stick them in the side, further reducing roll over chances.
   / Can a Kubota L2501 move a round bale? #15
I seriously doubt the tractor will lift a 1200 pound bale at all with the loader. I think you could lift a 1200 pound log on pallet forks, but a bale pushes the weight farther forward.
   / Can a Kubota L2501 move a round bale? #16
I have an L3901 and no way will I use it for moving round bales. 1200lbs, which I doubt is possible for that tractor, is asking for trouble.
The little L tractors are fine machines for what they are, but the lack of weight makes them marginal at best for loader work...
   / Can a Kubota L2501 move a round bale? #17
I had a L3200, same loader & frame as the L2501. I helped a friend move a small barn full of "1,200lbs" big square bales. I got the job done, but it was sketchy as ****. If I recall the loader is rated to 1,200lbs at the pins. Add in a couple hundred lbs for the forks & a decent bit for the load being well in front of the pins & I was well past the OEM rating.
I had a 5' rotary cutter on the back & a small pile of 50lbs bags of stuff on the back of that. Loaded R4 tires too. Lots of ballast & it was located a lot further back than normal for better performance. It still really wasnt enough. The back end was really light & pretty much came off the ground at least once.
The lack if ballast is guaranteed to be the weak point on the economy L 2 & 3 thousands, possibly the "frame". My new L4060 on the other hand is rock solid at max loader lift with just loaded tires (I keep ballast on the 3pt pther than that one time). So hydraulics & loader design are the weak spot there. Probably closely followed by the front axle, but that's just a guess. Everything has a weak spot, so that's not a complaint against either machine. Just s matter of where that weak spot is. Hopefully it's a power or ballast weak spot, not a structural issue.
I was lucky if I could lift a bale high enough to stack it on another bale. It depended on how lucky we were with the weight of a given bale.
In short, a L2501 might be able to lift your bales. But it wont be able to do it safely. You can probably get away with an occasional bale, as I did. But plan on getting a bigger machine if you plan on moving big square or round bales.
Do you wish you would have purchased larger?
   / Can a Kubota L2501 move a round bale? #19
Good point
   / Can a Kubota L2501 move a round bale? #20
Oh, you'd be reasonably safe moving the bales on a 3pt bale spear as opposed to the loader.
If the rear wheels come off the ground, the tractor will immediately roll to one side on the front axle pivot pin. Then hit the axle stops & almost assuredly keep rolling over.
If the front wheels come off the ground things aren't likely to be as bad. The solid rear axle wont ever roll side to side. It's easy to add ballast to the bucket to prevent that issue too.
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
2009 Ford F-750 Forestry Chipper Dump Truck (A55973)
2009 Ford F-750...
2012 MACK PINNACLE (A58214)
2012 MACK PINNACLE...
