Can a diesel engine run on gas. .
   / Can a diesel engine run on gas. . #21
Unless fuel is different in the US ... diesel distillate and petrol/gas mixes well.
There are a few of grades of diesel, cross contamination and even partial with a cheaper "extender" substitution. Over our way a few years back we had an issue with petrol/gas being adulterated leading to issues. Diesel there's talk they sometimes let way too much wax fraction into diesel during hot summer periods, not just a summer blend but scorcher blend.
Interesting bit about deliberately mixing it in during the cold at wikipedia ... but applies to older engine design.
   / Can a diesel engine run on gas. . #22
BOOM!!!!!
willy
   / Can a diesel engine run on gas. . #23
We had an apprentice (Dan) years ago that filled up a diesel welding machine with regular gas. He then got the nickname "Diesel Dan" , and it stuck with him for the rest of his life!
   / Can a diesel engine run on gas. . #24
Been there, had it done.
I've had diesels since a '79 VW Rabbit (65mpg:) ). So I've always been very careful. Traveled TDY to Europe quite a bit usually in a group.
Friend put about 5 liters of gas into a rental VW TDI, then topped it off w/ diesel (~60L total).
Ran rough as HE%%. But we found if we mixed it it would run. So for a few days we'd come out of places, jump on the fenders and shake it up. Really got odd looks.
Had the reverse happen, luckily to lawnmower, put diesel in a gas engine.
Son filled up small pull start lawnmower, darn near wore out my arm before I thought to sniff the tank.
IIRC in general older diesels can take up to 25% gas and still function.
   / Can a diesel engine run on gas. . #25
If you're lucky, not too much damage occurred. After you have drained every last ounce of contaminated fuel out, I think that just to err on the side of caution, I would change the oil and the replace the fuel filter.
   / Can a diesel engine run on gas. . #26
Good thing this wasn't a late model diesel truck. It is not unheard of that the proud owner of say a Ford 6.7 liter diesel pickup shells out upwards of $10,000 to undo such a mistake. Crazy money!
As for putting tainted fuel BACK into the fuel tank after diluting with additional diesel? Not me. Not even on a bet! Dispose that junk.
   / Can a diesel engine run on gas. . #27
Going through the Dakotas I filled up my diesel next to a guy who had a service truck and 2-3 mechanics pulling lines and purging gas from his system. Terrible mess. I thought to myself, glad that wasn't me.
Couple years later I bought a new GMC Dmax Dually and was pulling a 37' camper. After arguing with wife about if and where to get diesel we finally settled. I already had 1/2 tank and didn't want to screw with it.
I bitterly pulled up to a pump with 37' fiver in tow late at night and started pumping. After I was done pumping the wife says I got charged the wrong price. That was an oh chit moment. I just pumped 20 gallons of premium gas in my 34 gallon tank.
After begging for help to no avail I was able to cut a 1/2"water hose off for syphoning and got 32 gallons approx out of it, of diesel and gas mix. Lucky for me I never touvhed the key. I refilled with diesel and off we went. I stopped at a diesel mechanics and he said I was okay, just dump a quart of transmission oil in tank. It all was good after that and I keep that hose handy.
Now, every time I fill up I stay lazer like focused.
   / Can a diesel engine run on gas. . #29
I thought diesel nozzles were different in diameter than gas nozzles, so they could not be inserted into the wrong filler tube. I guess they are larger...to protect the minority!
The minority being diesel vehicle owners, who must be considered smarter than the average driver.
   / Can a diesel engine run on gas. . #30
They are considerably bigger, which means that you can conceivably fill your tank with gas instead.
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
Compressor (A55973)
Compressor (A55973)
2835 (A58376)
2835 (A58376)
Dewalt DWM120 5" Deep Cut Variable Speed Portable Band Saw (A59076)
Dewalt DWM120 5"...
Survey Kit (A57149)
Survey Kit (A57149)
