Can A 3-Point Hitch Implement be Attatched to a Tractor With Only A Drawbar?
   / Can A 3-Point Hitch Implement be Attatched to a Tractor With Only A Drawbar? #1
Noah H.
Friday Harbor, Washington, United States
1945 Farmall A, 1948 Case VAH, 1946 Perrin
Hello,
A friend recently offered to give me a Massey-Ferguson sickle bar mower that has been sitting in his field for the past few years. I looked at it and it has only surface rust and is in good shape, and It would make a nice addition to my small collection of tractors. However, the only tractor that I have that is of the right size to safely use the implement is a '45 Farmall A, which has no 3-point hitch but rather a solid drawbar. I have seen adapters intended to adapt a 3-point hitch to a trailer but never ones to adapt a drawbar to a 3-point hitch implement, I was wondering if these are even possible to get or if they simply don't exist. The sickle bar mower attaches to the back of the tractor and connects to the PTO, the Farmall has a PTO that would work fine for it. I am not sure what model sickle bar mower it is, but I suspect it is a model 41 or something similar. Is there a way I could attach this mower to a Farmall A without modification to either?
Thank you for your help!
Noah
   / Can A 3-Point Hitch Implement be Attatched to a Tractor With Only A Drawbar? #3
Anything is possible if you are a good fabricator with the proper welding and fabrication skills and a deep enough pocketbook. I believe you can get a 3 point hitch for your tractor commercially, but they aren't cheap.
   / Can A 3-Point Hitch Implement be Attatched to a Tractor With Only A Drawbar? #5
Or make a trailered 3 point hitch and add a longer pto shaft.
   / Can A 3-Point Hitch Implement be Attatched to a Tractor With Only A Drawbar? #6
It's what the Amish do and I bet you can purchase a 'Forecart' or whatever they are called in Amish country. Only instead of horses out front you'd have your tractor.
   / Can A 3-Point Hitch Implement be Attatched to a Tractor With Only A Drawbar? #7
My father made brackets that mount to the drawbar with a hydraulic cylinder to raise and lower on a Farmall M. He then made a 7ft box blade to drag the driveway. So anything is possible if you want it bad enough. I'll see if I can snap a few photos.
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
Sheets of Tin (A57149)
2007 Jeep Wrangler Rubicon, VIN # 1J4GA39197L104496 (A57453)
2007 Jeep Wrangler...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2171 (A58376)
2171 (A58376)
flooring (A55758)
flooring (A55758)
