Camp property search
   / Camp property search #141
I never stated what the current well depth is and do not know it. The owner put it in, likely with a hammer knocking a sand point down. I would guess far less than 40ft. The driller did say he put in his close-by neighbors well in that was nearly 500ft deep. Plus he said there was variety of water formation depths in the area.
That doesn't sound as bad as it first did. My first thought was a drilled well 8 feet from septic... That's a good way to pollute your water table.
Scary thing about drilled wells is that you don't know for sure how far down you'll go until he gets there.
He did, but I don't know how deep the point is. I'd guess shallow.
Dearest spent time reading thought the maze of safe water regulations written by an attorney and did find verbiage which made us think we could use a potable system or tank in this cabin and still be code. As the cabin's well and septic is set up now, we had no intention of drinking it anyway. Next week we will stop by the department of health and ask them about it. Ironically she worked for this government office for 7 years.
   / Camp property search #144
Guys, I'll try recall the well details the drilling guy told me. ------------------------------
Minim well depth was 40ft and most wells he does in that are are 40-50ft.
Minim distance between well and septic system is 50ft. This one is like 8!
A asked the driller about using the current system as non-potable only and he said "you can't do that" .
No sure if we could put in a potable tank or not.
This is the post that got me confused I think; most wells he does in the area are 40-50 ft deep.
Regardless, is testing the existing well and it being grandfathered in an option?
If you own it, its then grandfathered in, but when you get a bank loan, they want it to code.
   / Camp property search #146
Wait; I'm confused; we might need to go 500ft, but then in a few posts down, most in the area are 50-60 ft? Are we missing a zero, did we add a zero, or is this specific property unique (top of a mountain), that neighbors are 50-60, but yours will need to be 500 ft; or am I miss reading everything?
Our Oregon property had a hand dug well on it that was 30' or 40' deep. Then a drilled well that was 250' or so. Both of them tested at about 1.5 gpm over 4 hours. The lender (and ourselves) wanted better flow. We had a well drilled and it needed 500'.
The geology there is really variable. Well records are on line. There are neighboring properties that have 300' wells that deliver 25 gpm on the usual homeowner casing size, and some that are deeper and only get 2 gpm.
   / Camp property search #147
Is a well test being required for a lender common? I wasn't required to have more than the foundation certification, a 4 point wind-roof inspection, and appraisal. I did have the option of well, septic, insulation, and some others, but they were not required for the loan.
Dearest did remind me that code depth here is 50ft is minim. (correction, code here is minim of 25ft)
They do here.
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2012 VOLVO A40F OFF ROAD DUMP (A51242)
2012 VOLVO A40F...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52128)
J and L Cargo...
