Camp property search
   / Camp property search #201
The Barndo craze, I do kinda get their hold up. You have split use generally, partly residential, partly commercial or ag. That would likely require a 1hr fire wall from floor to cieling, separating the uses, at a min. At the same time... I never built a home with a garage, do they require a floor to cieling fire wall?
We build a "Lumber Tree" once, a covered warehouse type structure, without walls, where the supports had racks that held lumber, at a White Cap. It took a long time to permit, and eventually the state fire marshal got involved, and declared it a "building without walls"; and required signage about no gas/diesel/propane vehicles could be stored under it. At first they wanted active fire protection (wet pipe sprinklers), which would have drastically increased the price.
I (though work) permitted something once. Got a call, a local real estate broker owned a small parcel in town, that had an existing residential access. He says, he's building a small pole barn, with a single bathroom, 1 concrete ADA parking spot, and gravel parking, but it's a pole barn to store real estate signs. OK, talk to boss and get his blessing; existing access is fine for his land use. About 9 months later, the "pole barn" is a music venue... So, the access should Not have been residential, it should have been light commercial. Not much to do after it's open...
That above is probably what building departments/zoning folks assume a Barndo is going to be. Starts as a 3000 sq ft of residential with 5000 sq ft od "garage"; and next thing, it's a small machine shop, with the "residential" being offices/drafting, and the "garage" housing manufactering
Just for additional info; my past experience is all commercial and/or multi family; and current is all "horizontal" construction; never built a single family home and never reviewed or permitted one
   / Camp property search #202
The tiny house thing is a bit different and there are probably 2 or 3 main problems.
1) most are "non permanently affixed" sheds, that are not remotely to code for occupancy. No insulation, different wind loads, no heat, no water, no hot water, no breaker box, often just an extension cord pig tail, a light and an outlet or 2.
2) Around here, most really are a 16x30 shed, delivered on a roll off truck, and are about 1 step above a homeless camp made out of pallets and a tarp.
3) Most areas restrict the length of time of "continously camping", often 90 days or whatever, and if it's not a house, then it must be a camp, right?
4) Probably the biggest, and somewhat valid, but IMO, BS, people don't want their home next to a shed that people are living in... They think it will bring in lower income (and it might), and lower their property values (IMO if you wanted a say it what the property is used for, you should have bought it)
   / Camp property search #203
Not sure that 2x4 shed construction is any much different than 2x4 home construction materials these days other than the load design of the floor, but then some sheds are built as garages for vehicles. For sure, shipping containers are pretty strong structures. But I can see why people don't want a bunch of sheds used as houses around their neighborhood.
   / Camp property search #204
It's not all the shell construction, but their design. I'm guessing the sheds have something like a 25# live load roof design, so not wind load rated for an occupied structure. Even if built the same, it's just wasn't stamped for it.
Sheer walls; they normally have 3/8" or 1/2" T1-11, but that's vertical; doubt it meets 150mph sheer walls.
Now we have to have 5/8" drywall on all ceilings, and 1/2" is still ok on walls; but the sheds don't have any.
Even down to smoke alarms, all dwellings have to have heat, plumbing (including hot water), ect. Have to run the thermal calcs too, so you're going to need to spec the insulation values, windows (including direction of facing, ie, south facing windows are worse than north facing), ect
That's not to say sheds are bad, and I do think part od the fight against all of these (AFUs too), is part by builders, part by government zoning guys, and part by old time nosy folks.
It's kinda like the "no mobile homes" in some towns. There hasn't been a "mobile home" built in over half a century; manufactured homes by definition aren't the same; but a lot of towns still have the zoning rules about them, in fear of turning into a "trailer park".
   / Camp property search #205
BTW, I personally don't necessarily agree with the restrictions, I'm just giving the argument against them.
I also know that some tiny houses aren't shed based. Old neighborhood had one of the Styrofoam and stucco igloo. It took the owner like 3 contractors and 18 months to get it built, and now he has 2 travel trailers, and 5 sheds. Kinda takes the point out of a "tiny" house, doesn't it.
I have also seen some of the Amazon style fold out "boxable" homes for sale at auctions, brand new. They are Not liveable on delivery; you still need a tie down system, plumbing, electrical, and HVAC.
I do think the shed homes, tiny homes, ADU, and "urban camping" trends are just a sign of how bad young single folks are doing. These are hiding what is basically a boarder line homeless problem. Heck, my little brother bought an old ambulance with the plan to turn it into a home, before he got overwhelmed with what all it takes, and how much you have to do without to make it work.
   / Camp property search #206
The home affordability index is the worst it has been in the last 30 to 40 years. That is why people are desperate for anything they can afford, especially young people getting started.
Locale one FS. Looks rather small but we'll try see it in a week or so. Got many trips to Marquette planed.
Tiny House on Trailer​
now $23,900 was $29,900
Listed a year ago
a year ago
in Marquette, MI
Details​
  • Condition
    Used - like new
Tiny House for sale. 8' x 22', on a double axel trailer, with an added 9x11 finished room. - Fully insulated- Hardwood flooring- New Amana kitchen stove- Shower- Toilet- Carpeted living room addition with knotty pine ceiling - Detachable enclosed porch- Full insulation in walls, floor and ceiling- Heat: Propane and wood heat - New wood stove w/double walled chimney- Loft bedroom (11 x 7.5') with closet/storage (can fit king size mattress)- Study desk/computer nook- Ceiling fan- Multiple 120 electrical outlets.Pick up only, we do not deliver$23,900[hidden information]
   / Camp property search #208
Locale one FS.
Listed a year ago
a year ago
in Marquette, MI
Details​
  • Condition
    Used - like new
$24k for an 8x22, used.... A FEMA trailer from an auction or a 10 year old repo single wide is a Much better option at those prices. Heck, that's smaller than many bumper pull travel trailers.
Yes, we are looking for a few acres out of town with or without a camp (house) on it. We hope to have a few trails on it. Here is one we looked at on 40 acres plus a partially built house on it. Looked to not have been worked on in 4 to 10 years and never lived in and construction was DIY mess in many, many ways. The lookout on the roof leaks like a sieve. They must have pulled a camper here to work from. I'll post photos as we look at other locations. We contracted the realtor and not heard back.
View attachment 880229View attachment 880230View attachment 880231View attachment 880232View attachment 880233
They cut the price on this house. It ain't moving so its 140k now.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
