Camp property found, now updates.
/ Camp property found, now updates.
Heading out there after dearest gets away to meet with dirt contractor over drain field issues AND I'll take photos of the ground floor. Why do I forget to do that each time there??? 😠
/ Camp property found, now updates. #122
Last time we bought a house I took pics everywhere - main floor, upstairs, basement, crawl space (part of the house was crawl space, part basement) , attic --
It turned out really useful not only during the decision process but later as well I could avoid another crawl or climb when pondering work that needed to be done
Few photos taken yesterday evening.
/ Camp property found, now updates. #126
Wife just got an accepted offer on a 34 acre property, with 40x60 pole barn. Additional enclosed horse arena with stalls. 3500 square foot home, with a panic room... For $750k. Pretty good deal in these times. Place has two septics, two wells... Pretty fantastic for her buyers.
RE has gotten crazy expensive. Great if you have been a property owner and seen the value appreciation. Terrible if you haven't owned property and therefore didn't benefit from the run up.
One acre plots here are $30k... vacant. 6 years ago $6k was normal.
We found out from a well driller who works in that area this camp might be the in 500ft well formation.. Could be a deal breaker for us. :(
/ Camp property found, now updates. #129
There used to be a bigger per acre discount on large properties. Now, it seems like around me, a 50 acre property is running at least $9k/acre; and a 10 acre property might be $12/acre. Seems like 15 years ago, the % spread was bigger?
/ Camp property found, now updates. #130
Ours is 300'... Need a big pump for that head
/ Camp property found, now updates. #131
Yes, it's always been that way. Back in the late 80s we could by 1 acre lots in subdivisions for $15K, or 20 acres for $30K. (zoning prohibited anything under 20 acres with less than 600' of road frontage here).
Today, you can buy a 1 acre lot in a subdivision for $30-40K and 20 acre or larger parcels for around $8500 per acre, or $170K.
The land prices here started inflating rapidly in the early-mid 90s and has never stopped.
/ Camp property found, now updates. #132
Ours is 300'... Need a big lump for that head
Ours is 60' and the water table is less than 30'. Gotta be very cognizant of ground water contamination potential. Oil changes, chemical spills, etc. could spoil your and everyone around you's wells.
/ Camp property found, now updates. #133
Your eating a meal there Arly, looks like home! The cost of the well scares you? What are they doing for water now? I’ve got a friend with a large camp property with a cabin and he buried a tank for water. Since he’s there part time he just hauls water on occasion and it works pretty good. That’s always an option. That would be a good first project for the JD when you buy one.
Guys, I'll try recall the well details the drilling guy told me. ------------------------------
Minim well depth was 40ft and most wells he does in that are are 40-50ft.
Minim distance between well and septic system is 50ft. This one is like 8!
A asked the driller about using the current system as non-potable only and he said "you can't do that" .
No sure if we could put in a potable tank or not.
/ Camp property found, now updates. #137
40 ft for a potable well, wow. Don't know what the new house is, but old one was 105 ft, and still in the sand. Sure, you can hit water at 25-30 (in some areas all you need to do is kick the grass off and your at water table); but to get potable, I didn't think anything was less than 80 ft in the modern era.
/ Camp property found, now updates. #138
Wait; I'm confused; we might need to go 500ft, but then in a few posts down, most in the area are 50-60 ft? Are we missing a zero, did we add a zero, or is this specific property unique (top of a mountain), that neighbors are 50-60, but yours will need to be 500 ft; or am I miss reading everything?
I never stated what the current well depth is and do not know it. The owner put it in, likely with a hammer knocking a sand point down. I would guess far less than 40ft. The driller did say he put in his close-by neighbors well in that was nearly 500ft deep. Plus he said there was variety of water formation depths in the area.
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
