beppington
Elite Member
My friends & I like to sit around campfires/ bonfires at my place for hours on end, & these fires sometimes take a lot of attention in order to try to maintain an even heat output, so you don't have to move closer & closer to the fire, & then back away from it when somebody puts more wood on it or pokes at it.
I wonder if putting a big, thick chunk of steel in the fire would help stabilize the heat output, since it would also get hot & radiate heat more consistently than wood alone.
What do you think? Will it work? Anything wrong with this idea? Is it safe?
Any ideas on what large chunk of metal to use, where to get it, etc.?
I thought of maybe visiting a shop that repairs big rigs, & asking if they have an old, un-usable axle/ hub unit, so I could stand it up like a pole that would radiate. Or maybe an old set of dumbbells.
What got me thinking about this is a campground we stayed at that had an old big rig rim (or maybe a tractor rim; can't recall) laid out at each site for your fire pit, & the campfires we had in those seemed very uniform, like the rim was radiating and/or the rim helped the wood burn more consistently.
