Tires Camber Issues With Kubota RTV 1100
   / Camber Issues With Kubota RTV 1100 #1
jpinkston70
Glendive, MT
Kubota RTV 1100
I have a Kubota RTV 1100 bought it used in Missouri and had it brought to me here in Montana. When it got here i noticed it had a really bad camber issue on the front caused by the 2 inch lift kit that was already on it. I didn't pay much attention to it at first till about a month or so later when I noticed my tires were wearing really badly on the outside. I took off the lift kit on the front hoping it would help. It slowed down the wearing but it is still pretty bad. Is there any way to correct this problem?
   / Camber Issues With Kubota RTV 1100 #3
Does it have the heavy duty struts that are needed for a snow plow? That causes a slight camber issue without the weight of the blade. I don't think it would tear the tires up unless you drive it a lot on solid sufaces.
If you look at the lower part of the push bar, you might be able to tell if there was a subframe bolted there, also there may by hydro lines in the front.
Just a thought.
No It doesn't have the hook ups for a plow. As for the tire wear I drive it on the streets here in town since Montana allows ATV's and UTV's on the streets. I'll get outside and look though just to be sure.
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
19010 (A48082)
19010 (A48082)
UNUSED AGT QUICK ATTACH HYD HAMMER (A51244)
UNUSED AGT QUICK...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
